Nailing Into Gas Or Freon Lines
Old 10-10-2009, 01:44 PM   #1
Javelin350's Avatar
Trade: James Hardie Hardiplank siding Gold contractor
I know my fellow siders out there have done this once. One guy on my crew hit a freon line and a gas line hours apart. I keep telling these guys make sure u find the center of the stud. A lot of times some of these old houses the studs are not 16 on center. Would u dare to repair the line yourself of have a company fix it for you. When it comes to freon lines I can't service the system so yea have someone else do it. On the gas lines all the tech does is flare the lines and put a coulper in. Sounds and looks easy enough but would you do it?
Javelin350 is offline
Old 10-10-2009, 01:51 PM   #2
kbsparky's Avatar
Trade: Electrical
Re: Nailing Into Gas Or Freon Lines
Nope. Too much liability in either case.
Would you consider doing such repairs if someone else hit those lines? I didn't think so ...
kbsparky is offline
Old 10-10-2009, 02:03 PM   #3
Steve
BACKWOODS's Avatar
Trade: Remodeling and Custom Cabinets
If you have to ask, DO NOT DO IT.
BACKWOODS is offline
Old 10-10-2009, 02:11 PM   #4
Javelin350's Avatar
You are right thats why i call the Hvac guy when that happens. Last time it was 380$ to flare a freakin line in 15 minutes glad i did't pay for it the installer did. But your right I'm not paying if the house blows up from a gas leak.
Also power wires we have ran into hitting. Whats the deal with guys running wire right through the studs, i know u got to sometimes but were supposed to be nailing into the stud, right? is it my fault when my 2 1/2 inch nail shoots into a wire going right through the stud. Now i have to tear off the siding guessing where i hit the wire tear of the osb or what ever and fix the problem. Then with hardie say I know where the wires are and do not hit the studs in thoes areas, now the siding is all lose and looks like junk. I can pin nail any loose spots but no HO wants pin nail heads all over there brand new siding. Oh well just one of my headachs in the business. I'm sure I'm not the only one. Would like to hear from others about this situation
Old 10-10-2009, 02:24 PM   #5
Pompass Ass
bwalley's Avatar
If it was a refrigerant line it should have been brazed and then a vacuum pulled on it and then the system recharged, it takes more than 15 minutes to do it properly.
bwalley is offline
Old 10-10-2009, 03:00 PM   #6
Javelin350's Avatar
natural gas line i was speaking of haven't seen the freon done
Old 10-10-2009, 03:15 PM   #7
Fentoozler
Celtic's Avatar
The electric lines need only be 1 1/4" from the face of the stud.
Do you need 2.5" nails?
[I have no idea, I don't side]
Celtic is offline
Old 10-10-2009, 03:36 PM   #8
Javelin350's Avatar
thats what my contractor supplies and says thats what hardie recommends
Old 10-10-2009, 03:39 PM   #9
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Also power wires we have ran into hitting. Whats the deal with guys running wire right through the studs, i know u got to sometimes but were supposed to be nailing into the stud, right? is it my fault when my 2 1/2 inch nail shoots into a wire going right through the stud. Now i have to tear off the siding guessing where i hit the wire tear of the osb or what ever and fix the problem. Then with hardie say I know where the wires are and do not hit the studs in those areas, now the siding is all lose and looks like junk. I can pin nail any loose spots but no HO wants pin nail heads all over there brand new siding. Oh well just one of my headachs in the business. I'm sure I'm not the only one. Would like to hear from others about this situation
I think there is some scary sh*t contained between the lines of all this.
I'm scared to guess how you are 'repairing' electrical lines, plumbing and HVAC.
Code puts electrical lines through the center of a stud to avoid being hit by drywallers on the inside and siders on the exterior doesn't it? Are you hitting lines that are through the center of studs or are you hitting stuff that is off center and toward the exterior?
If it was me I'd look to have something in my contract to recoup those expenses for hidden damages caused by mis-installed lines that aren't installed where they should be and be out of harms way.
Mike Finley is offline
Old 10-10-2009, 03:44 PM   #10
Chief Toilet Mover
Hardie recommends 1 1/2" - 2" nails.
Old 10-10-2009, 03:56 PM   #11
Javelin350's Avatar
I'm not the one fixing the damages I've been lucky enough in my 6 years of siding not to hit anything. But my crew members have and we always have to have it done my a trades men in that field. I would love to fix it myself but don't need the problems down the road if my fix fails. I think i need to talk to my contractor if u say they recommend 1 1/2 --2 inch nails. even are pin nails are 2 1/2 inch. Thats why I really like this fourm to speak to differant people and hear there reviews.
Old 10-10-2009, 04:05 PM   #12
72chevy4x4's Avatar
If I recall, the recommended length of nail for vinyl installation is 3/4" protrusion. I've used 2 1/2" on resides through 1/2" foam, 1/2" sheathing and 1/2" wood siding...that leaves the recommended 3/4" nail through the sheathing. maybe it's time to check into the proper fastener size.
regarding fixing something yourself, how do you know if you've hit an electric line? for gas lines, again, how do you know it was pierced? I'm sure you know better regarding fixing it yourself. I have some friends who lived a few houses down from someone whose house blew up in the middle of the night due to a gas leak. http://www.pgslegal.com/CM/Custom/Se...dNegligent.asp it's not the same situation as what you're describing, but to even take a chance with something as dangerous as gas is ludicrous. in addition to looking into the proper fastener length maybe the addition of a damage clause due to hitting buried lines is in order.
72chevy4x4 is offline
Old 10-10-2009, 04:06 PM   #13
Chief Toilet Mover
Well, I don't know what a 'crew member' is. Must be a sub pretending to be an employee? Or is it a real sub? Either way, no matter what I was or was being called, if I was the actual guy who paid the guys directly who were installing the siding, I'd look into it pretty hard to not be paying for hidden defects of a homeowner's house.
Instead of talking to your 'contractor' whatever that means, how about just downloading Hardi's installation instructions?
Everything always defaults to the manufacturers recommendations for installation, you shouldn't ever be at fault if you read the directions on how to do something.
Old 10-10-2009, 07:32 PM   #14
72chevy4x4's Avatar
only options to me are 1 3/4" and 2 1/2" nails by the 50lb box.
Old 10-10-2009, 08:46 PM   #15
reveivl's Avatar
Trade: Renovations
And if they are not the right length for the application, would you use them anyway, and suffer the consequences?
reveivl is offline
Old 10-10-2009, 10:16 PM   #16
tccoggs's Avatar
2 x 6 framing sure is nice, you don't have to worry much about this situation.
For hardie over 1/2 ply 2x4 wall, I would use 1 3/4 SS siding nails. I would only use a 2 1/2 over foam. 1 inch penetration into the stud is plenty.
If you can't get them locally, there are plenty of online suppliers, I have purchased from fastenerusa.com when I can't find something locally. I only use stainless on exterior work, when siding my own house, the difference between HDG and Stainless was only $75.
tccoggs is offline
Spray Lines On Smooth Exteriors HELP!!! Entrepreneur Painting & Finish Work 15 04-03-2009 08:15 PM
Plumbing air compressor lines CNC Plumbing 6 02-07-2009 02:47 PM
Retrofit Sheer Wall Nailing? confluencebuild Carpentry 0 01-09-2009 01:26 PM
Nailing cedar bevel siding Chris B Carpentry 2 08-25-2008 03:33 PM
GAF nailing strip Jaketoo Roofing 12 08-10-2007 07:58 PM
