Metal Brake Projects.
Old 03-01-2009, 07:00 PM   #1
Gary H's Avatar
I am in the process of trying to make shutters out of coil stock. Have any of you ever made a cool project or item out of coil stock on a brake?
Gary H is offline
Old 03-01-2009, 07:02 PM   #2
mikec's Avatar
Trade: remodeling contractor
Re: Metal Brake Projects.
Why?
mikec is offline
Old 03-01-2009, 07:16 PM   #3
Gary H's Avatar
Why not?
Gary H is offline
Old 03-01-2009, 07:18 PM   #4
Trailer park boy
shanekw1's Avatar
I'd think they would be awfully flimsy, no? Not knocking it, just never heard of it.
shanekw1 is offline
Old 03-01-2009, 07:36 PM   #5
Gary H's Avatar
You would build this on 1/4 plywood as the base. It is the same thickness as fanfold so it planes out the same. I am going to build these in the warm shop at home. Then install j-channel around it , then siding. These are made to stay on.
Gary H is offline
Old 03-01-2009, 07:42 PM   #6
Gary H's Avatar
Living in Michigan I have lots of free time. And with 5 brakes,trimformers,slitters,and cutters just sitting around ,i can use all that scrap white alum. off jobs and build something cool. A few siding contractors make all thier own fasica, j-channel, window trim, and water tables around the house. We see very little plastic trim on houses. Most everything is alum. coil stock.
Gary H is offline
Old 03-01-2009, 08:00 PM   #7
Patrick's Avatar
w ow That must look great especially with the J channel around it
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline
Old 03-01-2009, 08:10 PM   #8
Gary H's Avatar
The siding butts into the j-channel. Just like j-channel around a window. But this shutter sits next to the window, then the siding goes around the window and shutter.
Gary H is offline
Old 03-01-2009, 08:24 PM   #9
Patrick's Avatar
Must look really really really nice, must be why the house values keep dropping in michigan
Patrick is offline
Old 03-01-2009, 08:37 PM   #10
Gary H's Avatar
Yes, that is the reason our house values are dropping.
Gary H is offline
Old 03-01-2009, 09:04 PM   #11
The Deck Guy
Greg Di's Avatar
Gary,
I have never seen a shutter sit in plane with any siding.
Shutters should sit on top of any siding to maintain the illusion that a person could actually "use" the shutters.
Right????
Greg Di is offline
Old 03-01-2009, 09:43 PM   #12
Gary H's Avatar
Greg ,
Good question. The frame of the shutter will be about 2'' thick. J-channel will take up half of this. So 1'' will stick out. I can make this any thickness to match whatever will look good. Also the center will be divided by a slightly recessed 2'' piece. so I will have two rectangle areas. I was going to fill this in with a piece of stock creased corner to corner. Vanmark used to have a picture of what I am trying to make. I don't know if they still have it on thier web site.
Gary H is offline
Old 03-01-2009, 09:49 PM   #13
Gary H's Avatar
Here is another angle of what I am trying to do. I want the shutters to have the look of being built in. When they sit on top of the siding, you see the gap behind the grooves of the siding. The idea is to build them, so from the side this gap is eliminated.
Gary H is offline
Old 03-01-2009, 09:52 PM   #14
Patrick's Avatar
LOL like a REAL shutter!!
Patrick is offline
Old 03-01-2009, 09:57 PM   #15
Gary H's Avatar
You are catching on fast.
Gary H is offline
Old 03-01-2009, 10:10 PM   #16
Tom Struble's Avatar
Trade: siding
bout time you figured it out Patrick shees
Gary post some pics when your done
Tom Struble is online now
Old 03-02-2009, 02:56 PM   #17
rojigga's Avatar
Trade: Exterior Finishing
The whole idea seems a little strange to me. If it were me I'd at least be trying to eliminate the J-channel by building that into the shutters. But if it were me I probably wouldn't be trying any of this!
At the end of the day will it be worth it? Or even look as good as the real deal? Or even close?
rojigga is offline
Old 03-02-2009, 03:01 PM   #18
Sophisticated Siding Guy.
thesidingpro's Avatar
Trade: Siding and Trim Specialist
I hate it when people think that having 5 breaks means something.
All i can say is post a pic on the shutter idea. I'll take a pair of vinyl ones for $40 any day over this approach and i've got extra brakes and scrap coil myself.
thesidingpro is offline
Old 03-02-2009, 03:54 PM   #19
user38755's Avatar
Haven't tried bending up shutters. Have to see it I guess. Here is some full custom bent window wrap. Covers stop and leaves storm ledge. Wraps brickmould, deep v for rigidity, and bent in J channel. Take it easy on me guys.
user38755 is offline
Old 03-02-2009, 03:55 PM   #20
Trade: siding
maybe he lines them all up for long bends
thesidingpro (03-02-2009)
Metal roof question Burby Roofing 11 01-22-2009 01:16 PM
Workers waiting for projects recruiter_t Help Wanted or Looking For Work 1 10-17-2008 09:23 AM
how to bid metal stud projects Wensdy Drywall 1 04-04-2008 01:46 PM
