Material Choice For Fascia.
Old 07-26-2007, 02:12 PM   #1
kclapper's Avatar
Trade: I am a licensed contractor that has been building homes and doing remodeling for 20 yrs.
Exclamation
Hi Guy's new here.
I was looking for some ideas on which material to use on my homes new addition. I am at the point to where i have to install some fascia material. I have a contractor lined up to install the new cedar impression vinyl siding and aluminum trim work. I just wanted to know what the rest of you siding and trim contractors use as a fascia material that is going to be covered with aluminum coil stock. He suggested rough sawn 1x6. I am a little leary of the roughness and cupness of this material from past usage during other applications. Is there any other cheap alternative material that everyone uses. Would appreciate some help. Thank's Guy's.
kclapper is offline
Old 07-26-2007, 04:20 PM   #2
Cabinetmaker
skymaster's Avatar
Trade: Cabinetmaker
Send a message via AIM to skymaster
Re: Material Choice For Fascia.
What about Azek or its cousin's and not having to wrap it?
skymaster is offline
Old 07-27-2007, 08:17 AM   #3
Tom M's Avatar
Rough sawn? You mean spruce. Ive used spruce on fascia boards for years knowing It would be covered in aluminum. If the eave has a gutter I will use #2 pine. I just tried the aztek nice stuff comes white only but soft and scuffs easily. Its also expensive even if you compare the cost of aluminun and wood verses just this board.
Tom M is offline
Old 07-27-2007, 05:22 PM   #4
Patrick's Avatar
Every new house we do just has a 2x6 or 2x8 if its gonna be wrapped
Patrick is offline
Old 07-27-2007, 08:29 PM   #5
kclapper's Avatar
Thank's for the info guy's. I purchased some 1x8 and 1x10 pre-primed #2 pine. I installed it today. It's only a small 12x12 dining room extension.I had to mock it up to the exsisting house. It has a 2' soffit with a 2x6 sub-fascia. I had to install a fascia to match the original. 1X8 fascia. I'm not a vinyl siding contractor. I guess in the future i can just cap the 2x stock used to cap the rafter ends.
kclapper is offline
Old 07-31-2007, 11:14 PM   #6
Expert Roofer
theroofinggod's Avatar
Trade: ROOFING/HOME IMPROVEMENTS-WINDOWS/SIDING/GUTTERING/COPPER WORK,ETC
Send a message via MSN to theroofinggod Send a message via Yahoo to theroofinggod
yeah that`s the way to go if you`re capping it,as long as your roof and gutter flashing are good you`ll never have a problem w/#2 pine
theroofinggod is offline
deck material smarks General Discussion 12 12-12-2007 03:59 PM
Choice composite decking turned into Junk John Hyatt Decks & Fencing 1 05-18-2007 12:41 PM
Opinion about material pricing eXpatRioteX Construction 9 03-12-2007 02:53 PM
Question regarding surplus electrical material solcam Electrical 2 07-25-2006 06:31 PM
Paying for material 6stringmason Masonry 24 03-30-2006 09:10 AM
