Marvin Tilt Packs
Old 03-10-2008, 04:20 PM   #1
painterman's Avatar
Trade: Historic Restorations
Rewards Points: 288
Marvin Tilt Packs
I have a request to install Marvin Tilt pack window kits. I have install similar kits like these before and found them very hard to install in openings that are not square. These kits will have to fit into an opening about 40 x 66. Any comments on these kits.
painterman is offline
Old 03-10-2008, 04:56 PM   #2
Preserving the Past
Jason Whipple's Avatar
Trade: Restoration & Historic Preservation
Rewards Points: 2,060
Re: Marvin Tilt Packs
I've done a few jobs with Marvin tilt packs. As you pointed out if the openings are out of square they wont work right. Try the "ultimate" tilt pack if the opening are bad. It's alot like a replacement window but made by Marvin. If they insist on the tilt pack only then DO NOT get aluminum clad sashes unless it's perfectly square. You'll need wood sashes so they can be plained down on the top or bottom sashes (or both).
I do great with these when all goes well. I did 6 of them last fall in about 3 hours. I had to slow it down a little when I found out how easy it was going to go. Walked out with $1200 for labor that day.
Jason E Whipple, General Manager
Historic House Restoration, Cincinnati, Ohio
Facebook | Twitter
Jason Whipple is offline
Old 03-10-2008, 05:00 PM   #3
oldfrt's Avatar
Rewards Points: 94
I installed them once several years ago and found them extremely hard to tilt in for washing .Unless they changed their design I'd be concerned about how easy they will work for the HO.
oldfrt is offline
Old 03-10-2008, 05:07 PM   #4
Preserving the Past
No different today. They are really tight. The last people I put them in for broke a sash trying to do just that (clean them) Marvin did replace the sash at no cost though. I'm not a compression jamb fan at all, but some people want them.
Facebook | Twitter
Old 03-10-2008, 05:07 PM   #5
Patrick's Avatar
Rewards Points: 2,364
If it aint got a frame, and go in as one unit, I want NOTHING to do with it.
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline
The Following User Says Thank You to Patrick For This Useful Post:
HAT (09-14-2011)
Old 03-10-2008, 05:08 PM   #6
Siding Windows Doors
easy sider's Avatar
Trade: Exteriors
Rewards Points: 250
These are to easy to install even if the opening is a little out of square.
easy sider is offline
Old 03-11-2008, 02:05 PM   #7
TimNJ's Avatar
Rewards Points: 2,470
It's been years since I installed any of those tilt pacs. I hated them then, so I would probably still hate them. And I really like Marvin's "regular" windows.
TimNJ is offline
Old 03-16-2008, 08:22 PM   #8
Windows Plus
Kenny K's Avatar
Trade: Replacement of windows,siding and doors
Rewards Points: 150
most economical.
Kenny K is offline
Old 03-16-2008, 08:39 PM   #9
Al Smith
A W Smith's Avatar
Rewards Points: 1,000
Me too. I posted elsewhere here that the old lady who insisted on the tilt packs could not even tilt them. I do not recommend them. For two sashes that come in a pizza box and a balance kit they sure are pricey.
Al Smith
http://www.awsmith.com
A W Smith is offline
Old 03-21-2008, 04:55 PM   #10
tin man's Avatar
Trade: windows and siding
Rewards Points: 150
Be sure to sell them storm windows also ,they sure are drafty.
tin man is offline
Old 03-21-2008, 07:03 PM   #11
genecarp's Avatar
Rewards Points: 2,000
if it is a whole house, get the marvin rep to come out and measure up the openings for you, if something doesnt work out, you can blame him
genecarp is offline
Old 09-10-2011, 10:08 AM   #12
austinguy's Avatar
I installed 7 of the tilt pac sash kits with compression jams from Marvin two years ago. The homeowners hate them. Can't open them worth a darn for cleaning and they are on the second floor. It's basically a fraud that they can be opened at all.
austinguy is offline
Old 09-14-2011, 12:22 AM   #13
HAT's Avatar
Trade: Windows & Doors
Rewards Points: 25
With the advent of insert DH's & casements there really is no use for tilt-pacs anymore.
If the H/O is sold on Marvin then go with their insert DH or Ultimate Replacement Casement.
If they were going tilt-pacs strictly for price, you can get a 3-1/4" clad insert from a brand like Lincoln or JW Siteline for not too much more than a Marvin tilt-pac.
The new Milgard Essence line has an insert option too....Fiberglass Ext. x wood Int with a lifetime warranty including glass breakage. Haven't priced it enough to know where it fits economically though.
HAT is offline
anderson and marvin windows Helen Windows, Siding and Doors 4 12-02-2007 06:43 PM
Marvin Venting Picture Window/ Useless? dougchips Windows, Siding and Doors 3 10-29-2006 09:59 PM
tilt panel job michaelray Construction 3 09-01-2005 06:52 AM
