By strictest definition, breather tubes and capillary tubes are different animals.
Cap tubes are long, very narrow, stainless steel, and remain open even when the window is installed, while breather tubes are short, with a wider opening, generally aluminum, and they are closed once the IG acclimates to the installation location.
If a unit is going to be installed at higher elevations, either cap tubes or breather tubes can be used. If the IG manufacturer uses cap tubes they will never be sealed. If they use breather tubes, then see the previous paragraph.
One thing common to both is that no one (that I am aware of) fills a unit with argon and then uses cap or breather tubes. It is self defeating. Argon is going to be gone pretty quickly if the airspace is open to outside air.
