Jeld-Wen Window
Old 01-10-2017, 08:51 AM   #1
PlasmaGuy's Avatar
Trade: Metal Fabrication.... Job Shop, Sandblasting
Rewards Points: 93
Jeld-Wen Window
I built a house 10 years ago using Jeld-Wens SeasonShield window.
I have had an interior window pane break. They warranty for only one year on this type of break so I have to fix this on my own. Is there any options on the table to have this unit built locally or am I better off getting them to supply the glass?
This is a fixed window and broke in the middle of the night in my bedroom. It scared to crap out of me. The rep said that "these things happen".
https://goo.gl/photos/9YUfCcfzbEbJJXjG9
I hope this doesn't become a winter thing
Thanks guys,
PlasmaGuy is offline
Old 01-10-2017, 09:32 AM   #2
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 298
Re: Jeld-Wen Window
Have you tried to see what a replacement glass unit will run from them? A good glass shop that makes themo units can do it too. Not to hard to replace. But JELD-WEN would be the best as they can make the to fit right just off the model number.
Randy Bush is online now
The Following User Says Thank You to Randy Bush For This Useful Post:
overanalyze (01-10-2017)
Old 01-10-2017, 10:22 AM   #3
PlasmaGuy's Avatar
Rewards Points: 93
Re: Jeld-Wen Window
Randy,
Thanks for the reply.
I just received a quote for material and labor.
$65.00 for the window
$192.00 for the labor.
I think this is a fair price.
When I called a local glass shop and discussed thermal windows I heard the "what's you talking about" thing from the lady on the other end.
Old 01-10-2017, 10:24 AM   #4
TLHWindows's Avatar
Trade: Windows Doors Siding
Rewards Points: 726
Re: Jeld-Wen Window
Good expansion to break it like that.
Ask JW for cost on a Glass replacement unit. A lot of times they will do it cheaper than a glass company will and you will get the same unit as you had before.
Cool, lets put some fabric over a window and let a hurricane throw some stuff at it. I'm sure it will protect you and your windows.
http://www.gulfbreeze-windows.com
TLHWindows is offline
The Following User Says Thank You to TLHWindows For This Useful Post:
Tom Struble (01-10-2017)
Old 01-10-2017, 08:37 PM   #5
PlasmaGuy's Avatar
Rewards Points: 93
Re: Jeld-Wen Window
TLH,
I failed to mention the above number is from JW.
The lady asked for me to measure the window frame on the interior. She said there had been some "changes"
I'd hate to think they arrive to switch out the glass and find the replacement was made too big . So much for shop drawings
Old 01-10-2017, 09:50 PM   #6
VinylHanger's Avatar
Rewards Points: 6,932
Re: Jeld-Wen Window
For that amount, I would let JW do it. Their windows suck to replace, as they use a seemingly self healing silicone. I would pull the stops though and measure the actual glass. They will know the overall thickness.
VinylHanger is offline
The Following User Says Thank You to VinylHanger For This Useful Post:
PlasmaGuy (01-11-2017)
Old 01-11-2017, 05:03 PM   #7
TLHWindows's Avatar
Rewards Points: 726
Re: Jeld-Wen Window
Agree, pull the stops, measure the glass. If you want to measure the overall thickness, use a something that will slip between the glass and frame, like a piece of aluminum trim and mark and measure. That will allow you to see if they are coming close to the same size.
Old 01-16-2017, 11:04 PM   #8
Andrade's Avatar
Trade: Glazing, Metal Fabrication, Storefronts.
Rewards Points: 38
Re: Jeld-Wen Window
I replace glass and something like that with mutton bars and annealed double pane with argon gas would be $275 installed, just to give you an idea of what it goes for if that helps any. GL
Andrade is offline
Old 01-19-2017, 08:21 AM   #9
Artworks's Avatar
Trade: Renovations & Construction
Rewards Points: 310
Re: Jeld-Wen Window
I had same thing happened to a 30 x 60 JW casement, couple months after their "warranty". ( I installed 9 windows in my own house) I will not recommend a JW window ever again!. I been in the buisness for 30 + yrs, and never had a problem with warranty's form any company. ( Duraco, All Weather, Kolbe & Kolbe, Lowen ect. ) & JW sealled units SUCK to replace ! My local lumber yard did replace the unit on good will ( my son is yard manager!).
I am just glad it wasn't a clients , because I would have had to "eat" all the costs . JELD WED WINDOWS NKG!
IF IT WAS EASY, EVERYONE COULD DO IT !
Artworks is offline
Weep holes in a picture window. RiverBG Windows, Siding and Doors 7 01-23-2015 11:41 AM
Need window protection? G. Trott Introductions 0 06-10-2013 03:31 PM
Kleer PVC for Bay Window Spencer Windows, Siding and Doors 7 12-08-2012 02:58 PM
how should I trim out the window siding?? lewisthepilgrim Windows, Siding and Doors 24 12-02-2012 11:46 AM
Making A Window Frame (Video) Cole Tools & Equipment 2 11-19-2012 09:21 PM
