Installing Wood Cedar Boards ???
Old 09-13-2009, 11:01 AM   #1
enforcer's Avatar
Trade: windows-siding
guys,i don't install those vertical wood cedar tongue and groove..is it much more expensive on both labor and material? have a custmer with a contemporary house built in 1990,they are thinking of doing vinyl or fiber cement but mentioned wood.i said wood is extremely expensive,more than fiber cement...
enforcer is offline
Old 09-13-2009, 01:14 PM   #2
lavrans's Avatar
Trade: General Contractor, Woodworker
Re: Installing Wood Cedar Boards ???
Any vertical application, whether wood or FC is going to be more expensive. You need to be more diligent with the wrap & flashing, need to install horizontal strapping to fasten to, but can't create water stops that will trap water. Simply installing over siding, even with WRB, is a recipe for replacement in a short period of time. Water wicks through much easier, so you really need to treat it as a rain screen design.
lavrans is offline
Old 09-13-2009, 04:21 PM   #3
davinci's Avatar
Trade: roofing
are the wood tongue and groove vedar boards(vertical) nailed or glued?
davinci is offline
Wood floors in an elevated bay house (Texas) Monarchy Flooring 22 01-30-2010 12:01 PM
Replacing damaged boards in hardwood floor woodworkbykirk Flooring 9 11-06-2008 08:56 PM
Alcove for Wood Stove Agolk2 Construction 0 09-02-2008 01:23 PM
Nailing cedar bevel siding Chris B Carpentry 2 08-25-2008 03:33 PM
Cedar wood stained - plazaman Painting & Finish Work 46 04-17-2008 01:24 PM
