Installing Windows W/ Foam Board
Old 04-24-2006, 05:08 AM   #1
mas's Avatar
Trade: gc
Does anyone know the proper way to install windows when you have to put foam 1.5" board over the whole outside of the house? would you build out the window with say a shim or 2x4 on face against the osb around all window and door openings so that the windows + doors dont look 1.5" resised into the house
thanks
mas is offline
Old 04-24-2006, 07:55 AM   #2
go dart's Avatar
Trade: remodeling/specializing in kitchen & baths
Re: Installing Windows W/ Foam Board
your on it. frame w/ 2x4s flat around window /door openings, butt foam to them. order or add extension jambs to the windows. wall thickness is now 6" ?
go dart is offline
Foam Board vs. OSB JimmyZimmier Framing 17 11-06-2010 05:54 PM
Installing Hardi Plank Siding around windows w/ J channel brownie77 Windows, Siding and Doors 8 11-21-2007 08:52 AM
installing basement windows in concrete blocks mtpgoat Remodeling 2 03-25-2006 10:06 AM
Installing New Basement Windows...(help!) bluethumbnail Windows, Siding and Doors 3 11-05-2005 11:04 PM
