Inside Corner Trim Fo Hardiplank ?
Old 11-16-2008, 10:23 AM   #1
jetfxr's Avatar
Trade: handyman
Residing a house with Hardiplank and Miratec trim. What is the best/ most popular material you guys have used for inside corners? Thanks
jetfxr is offline
Old 11-16-2008, 10:27 AM   #2
Sophisticated Siding Guy.
thesidingpro's Avatar
Trade: Siding and Trim Specialist
Re: Inside Corner Trim Fo Hardiplank ?
I first flash it out with some scrap coil stock. Then I use a 1x4.
thesidingpro is offline
Old 11-16-2008, 11:43 AM   #3
I used to think so.......
wallmaxx's Avatar
Inside corner...install a 1x1 or 2x2 rip into the corner first (if its to be painted) then, you butt your pieces into that.
wallmaxx is offline
Old 11-16-2008, 12:28 PM   #4
Stewy's Avatar
Trade: home improvements and renovations
I use whatever I am using on the outside corners.
Stewy is offline
Old 11-16-2008, 01:36 PM   #5
AtlanticWBConst's Avatar
We usually end up using PVC type trim like AZEK, KOMA, etc for the trim boards - so we rip down the same type stock to 1x1's and use that.
- Build Well -
AtlanticWBConst is offline
Old 11-16-2008, 02:52 PM   #6
topsail's trimcat
woodworkbykirk's Avatar
same here, seen guys run into vinyl inside corners but looks like
woodworkbykirk is offline
Old 11-16-2008, 03:04 PM   #7
Patrick's Avatar
WE don't even use vinyl inside corners for vinyl siding never mind hardie
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline
Old 11-17-2008, 10:08 AM   #8
jetfxr's Avatar
Trade: handyman
Thanks for all of your inputs. I was thinking of using a ripped 2x2 cedar piece, but had seen that some guys use metal inside corners. I was concerned more about the paint holding up on the metal compared to the Hardi. Thanks again.
jetfxr is offline
Old 12-20-2008, 06:54 PM   #9
Tom Struble's Avatar
Trade: siding
vinyl inside corners just dont seem to work well some guys here are using vinyl trim for corners .windows ,lineals ect. i dont get it tho,why not use vinyl siding then
Tom Struble is online now
Old 12-21-2008, 03:34 PM   #10
topsail's trimcat
very true tom, hardie to vinyl looks like crap, for the soffit ok, because the hardie soffit is a bastard to work with
the only vinyl around windows and doors should be the window or door itself, then run cape cod around it for the hardie to die into
Old 12-21-2008, 04:26 PM   #11
Kgmz's Avatar
We use white wood 2x2's.
White wood is a generic term around here for the preprimed exterior trim boards.
The brand our lumberyard carries is Real Trim by Woodtone. Link below.
http://www.woodtone.com/Products/RealWood/RealTrim.html
Kgmz is offline
Old 12-21-2008, 10:01 PM   #12
Trade: siding
ive had problems with the primed matierial windsor 1 is the one here with the finger joints blowing up even with priming the end cuts
Black marks left by inside corner applicator AARC Drywall Drywall 5 10-04-2008 09:41 AM
What would you trim the inside of an archway with? jackofsome Finish Carpentry 9 06-18-2008 10:25 PM
Help with - Inside corner trim for vertical cedar siding wallmaxx Framing 3 07-22-2007 06:47 PM
Ledger board flashing, inside corner mickeyco Decks & Fencing 3 12-12-2006 10:59 PM
