Inside Corner (lap Siding To Stone Veneer)
Old 04-07-2009, 08:54 AM   #1
It's Not a Toomaa!!
HandyHails's Avatar
Trade: Remodels
I haven't started yet, but here is the situation. I'm looking for opinions on what will look the best.
Hardi Plank, w/the six inch reveal on the side of the house (rancher) is going to butt into a wall of Eldorado dry stack stone veneer. I've got everything down as far as install of the stone and the Lap Siding, I'm just not sure if I should put the siding first and then the stone or vise versa to create a nice transitioin between the two materials. Keep in mind the stone varries from 2"-3.5" in width.
Right now my thoughts are to put the siding up first and butt the stone to the siding. Fill in any gaps w/ mortar. Any thoughts as to why this would NOT be the way to go?
Thanks in advance for your opinions and experience w/ this.
Josh
HandyHails is offline
Old 04-07-2009, 09:13 AM   #2
Steve
OCRS's Avatar
Re: Inside Corner (lap Siding To Stone Veneer)
I would try to install some sort of 1x4 corner block for both materials to butt up to
OCRS is offline
Old 04-07-2009, 09:36 AM   #3
It's Not a Toomaa!!
HandyHails's Avatar
Trade: Remodels
So just a piece of standard hardi trim would do the trick, right? That makes sense.
I should mention that this inside corner is under the front porch roof line and should never receive much moisture at all.
Old 04-07-2009, 09:44 AM   #4
Steve
OCRS's Avatar
This way you could skip the mortar in the corner as well, it'll probably just crack anyway
OCRS is offline
Old 04-07-2009, 12:55 PM   #5
It's Not a Toomaa!!
HandyHails's Avatar
Trade: Remodels
Your probably right. If I run the trim and then the stone, I could start the stone work against the trim and virtually eliminate any gaps.
Thanks for the help Steve.
Old 05-07-2009, 11:50 PM   #6
Burns-Built's Avatar
Trade: Residential Construction & Masonry
If this is a stacked stone why would you mortar between the stone and siding? I may be wrong but it is a dry stack i presume. I am also running into the same issue with a chimney. Except the siding is already run into the chimney and i have no choice but to run the stone up to the siding.
Burns-Built is offline
Old 05-08-2009, 05:30 PM   #7
KemoSabe
loneframer's Avatar
This is my preferred method.
loneframer is offline
Old 05-08-2009, 05:44 PM   #8
KemoSabe
loneframer's Avatar
As opposed to this.
Old 05-08-2009, 06:02 PM   #9
Professional Instigator
rbsremodeling's Avatar
I actually like how the stone against the siding looks verses having the 1x in between
rbsremodeling is offline
Old 05-08-2009, 06:46 PM   #10
KemoSabe
loneframer's Avatar
That is actually a picture of cedar soffit rotated for effect. I like the look too, but it took a whole day to scribe the soffit to the stone. I would have preferred the corner board to be protruding just beyond the outermost point of the stone, but it wasn't my call.
Old 05-08-2009, 06:47 PM   #11
I like Green things
WarnerConstInc.'s Avatar
I like that look better myself but, I vote for option one for ease and longentivity.
WarnerConstInc. is offline
Old 05-08-2009, 08:36 PM   #12
Tom Struble's Avatar
Trade: siding
i think either way as long as its done elegantly
masonary to wood connections always bother me i think hardie recomends a 1/4 '' spacing between the trim and masonary not sure tho
Tom Struble is offline
Old 05-08-2009, 09:11 PM   #13
Tom M's Avatar
Loneframer I recognized this house in your other posts'. I love that job....one too be proud of.
Tom M is offline
loneframer (05-08-2009)
Old 05-08-2009, 09:27 PM   #14
solar guy
naptown CR's Avatar
Trade: solar contracting
the trim piece looks better and this I assume is Hardi trin and not wood I would have a problem with masonry abutting wood
naptown CR is offline
Old 05-08-2009, 09:32 PM   #15
KemoSabe
loneframer's Avatar
The trim is all Azek. First job we've done with paint. We'll see what happens.
Old 05-08-2009, 10:06 PM   #16
solar guy
naptown CR's Avatar
Even better than Hardi
Old 05-09-2009, 08:08 PM   #17
rojigga's Avatar
Trade: Exterior Finishing
Maybe YOU should install the siding!
Good luck.
Ps. NAPTOWN: Hardi Trim sucks! Anything beats it!
rojigga is offline
Tyvek under 1/4in foam for Vinyl siding? PittTrack Windows, Siding and Doors 65 03-06-2011 10:16 AM
corner box or mud tube???? Kiwiman Drywall 22 07-31-2009 08:43 PM
Cast Stone NJ Brickie Masonry 9 07-23-2009 04:20 PM
windows siding doors Patrick Contractor Swap 6 02-06-2009 01:19 AM
Question about inside corners Lone Wrencher Drywall 36 12-08-2005 07:37 PM
