How To Replace Bottom 2 Courses Of Masonite?
Old 07-26-2005, 07:00 PM   #1
jimaymn's Avatar
Trade: Residential Remodeler
Bottom 2 course of garage siding and bottom 4" of sheeting rotting.
Plan: Stop water issue, replace the bottom 1' of sheeting, replace bottom 2 courses of masonite siding.
How can I replace bottom courses without damaging the above courses (pry out or cut out), and should I install a flashing or house wrap between new 1' of sheeting and siding?
Thanks, john
jimaymn is offline
Old 08-01-2005, 09:33 PM   #2
2b2s's Avatar
Re: How To Replace Bottom 2 Courses Of Masonite?
Replace the bottom course as normal, then cut a 1/2 inch off the top of the new piece u are replacing on the 2nd course, this will allow u to get the new siding under the plastic lock lip.
2b2s
Thanks, john
2b2s is offline
Rotten Beams - must replace MHMConstruction Remodeling 8 03-05-2007 04:45 PM
Repair or Replace? Greg Di HVAC 12 02-02-2007 10:36 PM
How much can you typically take off the bottom of a hollow core door? Dustball Windows, Siding and Doors 7 01-18-2007 10:36 PM
Help!-mold and masonite lourohar General Discussion 1 11-25-2006 11:41 AM
Replace Hot water tank? RussellF Plumbing 6 09-19-2006 06:32 PM
