Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Specialty Trades > Windows, Siding and Doors
Old 01-18-2007, 06:15 PM   #1
How much can you typically take off the bottom of a hollow core door?
I'm going to need to take off approx 3" off the bottom of four hollow core doors due to a low ceiling height. How much solid material is typically in the bottom of HC doors?
Thanks,
Dustin
Dustball is offline   Reply With Quote
Old 01-18-2007, 06:20 PM   #2
Insert title
dougchips's Avatar
Trade: Doors-Windows-Decks
About 1.25". You can cut them down and glue in a slug. If you are bored you can clean off the cut out section and glue it in. You will void your warranty either way. I have done this for over 10 years without any issues.
dougchips is offline   Reply With Quote
Old 01-18-2007, 07:06 PM   #3
Ready 4 Rent
Trade: Property Maintenence
I would say you can only take about one inch off, anything more and you definatlly have to replace the "inereds". I have just finished hanging 6 6-panel hollow cores, and each doorway a different height. Measured them one day, and came back to do the project 5 days later after I had cut all the doors at the shop, painted etc. And I didn't look good enough on the estimate, but the HO floors were far from level, (4 inchs out on some coming up from the doorways) So I had to re-cut, and re-hang them. (Only opened until they hit the un-even floor)
That was fun!
(Always learning)
Don't bother cleaning up the old core, just rip a new piece of wood to size. Little bit of glue 30 mins to set and done.
John
www.ready4rent.ca
John S is offline   Reply With Quote
Old 01-18-2007, 08:16 PM   #4
Student of Life
Murphy's Avatar
Trade: Remodeling, Restoration, and Repair
Take off what ever you need just brace the bottom of the door the way it was before and you will be fine.
Murphy is offline   Reply With Quote
Old 01-18-2007, 09:08 PM   #5
reveivl's Avatar
Trade: Renovations
My experience is the same as all the above, the only thing I'll add is that you might haveto dig out some weird cardboard/plastic baffles that are in there to get the new base in.
"Too much is always better than not enough"--J.R. "Bob" Dobbs
reveivl is offline   Reply With Quote
Old 01-18-2007, 09:27 PM   #6
Trade: Carpentry, Remodeling
Ditto all of the above. I will add that cutting the sides is a whole different ball game, and a losing one at that.
Chris G is online now   Reply With Quote
Old 01-18-2007, 09:47 PM   #7
Insert title
dougchips's Avatar
Side note, you can special order them almost any width and height for around $66.00.
Old 01-18-2007, 10:36 PM   #8
Thanks for the info. I've cut HC doors before but it was 1/2-3/4" at the most, haven't done 3" before.
