Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Specialty Trades > Windows, Siding and Doors
Old 06-22-2009, 06:41 PM   #1
Trade: building and remodeling
How do you handle flashing drip cap?
Using wood or azek drip cap on a window or door head always becomes a problem for me when used in conjunction with cedar shingles. The lip on the back is too short and in the past I have always bent a drip cap which is a pain because you have to bend it back to the wall right over the lip so you can get the shingle and the undercoarse over it without bulging out. I have also cut the lip off and ran a wider metal drip on top of it. So I was thinking what if I just put sort of a z flashing over the lip and up the wall like a counterflashing and not covered the top of dripcap at all. I never liked the way the metal looked hanging over the side anyway, unless it was copper. Water problem?
swanee is offline   Reply With Quote
Old 06-22-2009, 08:45 PM   #2
Copper flashing is my preference.
Josh Jaros www.jarosbros.com Remodeling in The Woodlands, Texas
jaros bros. is offline   Reply With Quote
Old 06-30-2009, 04:20 PM   #3
tomstruble's Avatar
Trade: siding
these windows have azek drip with aluminum z flashing
i rip the ''hump'' on top of the azek drip off
how-do-you-handle-flashing-drip-cap-img_1292.jpg   how-do-you-handle-flashing-drip-cap-img_1291.jpg
tomstruble is offline   Reply With Quote
Old 06-30-2009, 08:37 PM   #4
I have not done much vinyl siding before so. That being said I don't think I have ever seen drip cap, azek or otherwise used, in conjunction with vinyl. It has a nice look and it has got to better than having a jmoulding gutter on top as is usually the case. And yes I am going to rip the hump off and wrap it, thanks.
Old 06-30-2009, 10:37 PM   #5
tomstruble's Avatar
Trade: siding
the window trim on the sides were routed out to receive the siding the heads have a drip and flashing that returns to the sheathing,there is a j channel on top of the drip flashing to receive the bottom of the siding over the window
Old 07-01-2009, 08:25 AM   #6
Okay looking again I can see the j moulding. Most jobs I see around here they don't use flashing on top, just j moulding bent down on the ends into the side pieces and caulk.
need advice pinning down existing drip cap Brian (FL) General Discussion 15 05-12-2009 11:58 PM
drip edge ? wellbuilthome Roofing 67 03-27-2009 06:13 AM
Questions Shower Handle Inside matthewcims Plumbing 3 02-23-2009 11:01 AM
Flashing, step/pan/wall Burby General Discussion 19 12-24-2008 05:41 PM
