How Do You Guys Attach Your Aluminum Fascia?
Old 11-09-2007, 12:07 AM   #21
Sophisticated Siding Guy.
thesidingpro's Avatar
Trade: Siding and Trim Specialist
Re: How Do You Guys Attach Your Aluminum Fascia?
I'm talking on the face of the board. Once I slide it under the shingles I pull up a couple tabs and nail it there. Those nails get covered with the tab so there hidden. Then underneath I put a nail at each seam and one in the middle.
So each 10'6" board 8 nails holding it evenly spaced out.
I've ran a lot of siding and trim.
Check these windows out.
http://thecontractorsclub.com/window...ing-cp2-8.html
Here's some exterior skylights I did over the summer.
http://thecontractorsclub.com/exteri...hts-cp2-9.html
Patrick,
Next time I'm in the field installing some I'll try to take some pics for you. It's easy just hard to explain.
thesidingpro is offline
Old 11-09-2007, 05:58 PM   #22
dkillianjr's Avatar
Originally Posted by thesidingpro View Post
The least amount of face nails the better. If you run you trim nice and clean and can slide under the shingles you should only have one face nail at each seam.
Here's some trim on the job I'm currently working on. I bend my channel into my freeze board to receive the fiber cement.
http://thecontractorsclub.com/new-fo...p383-full.html
http://thecontractorsclub.com/new-fo...001-sp370.html
Here's some brake work I did a few months ago.
http://thecontractorsclub.com/new-folder-006-sp239.html
Hey sidingpro, Thats some nice looking work, next time I do hardie siding I'd like to use that aluminum idea for it. What kind of brake do you have? On that last link How wide is that top bend for the soffit?
dkillianjr is offline
Old 11-10-2007, 05:22 PM   #23
Thanks
I've got the tapco pro3. The only brake I would ever consider using. The rest are weak to say the least. IMO
I don't understand your question on th last link?
I make my pocket 5/8 and put a power bend in it to put downward pressure on the soffit.
Old 11-10-2007, 06:06 PM   #24
dkillianjr's Avatar
Sidingpro, I was just asking cause that bend looked smaller to me for some reason. I have a Vanmark mark 1 brake and maybe i'm crazy but I swear I can't bend anything like that under 5/8". Will the tapco do it or am I crazy?
Old 11-11-2007, 10:32 AM   #25
oldfrt's Avatar
The trick to bending under 5/8" is fairly simple if I can explain it clearly.
If I take a piece of scrap coil and place in my brake it under the piece I want to bend ,to say 1/2" ,I can get that bend. The piece of scrap coil will need to stick out past the face of the brake at least the width of the bend you're trying to make.Slide your work piece in to the width you want on top of the scrap,then tighten the brake and it should make the bend.
Basically you're bending two pieces together.
If I'm going to need some 90 degree bends,I get both done at the same time.
oldfrt is offline
Old 11-11-2007, 06:08 PM   #26
dkillianjr's Avatar
Oldfrt, thanks that sounds like a pretty cool trick I have never heard that before I will give it a try at thejob tomorrow for sure.
Old 11-13-2007, 08:48 PM   #27
72chevy4x4's Avatar
I nail from underneath the fascia/rake and 'pop' up the drip edge so slightly to nail. At the end of a run, I'll drop two nails in the face, but they aren't seen as the next piece covers them.
72chevy4x4 is offline
Old 11-13-2007, 10:41 PM   #28
dkillianjr's Avatar
Thanks chevy, Yep around here use drip edge too all the time it is deffinetly a good place to hide a few nails.
Old 11-14-2007, 07:13 PM   #29
In the gable I cover the drip edge up and on on hips I bend my own matching drip edge.
The cheap stuff the roofer's put on is junk imo.
Old 11-14-2007, 07:17 PM   #30
72chevy4x4's Avatar
hey there Louisville-do you have a picture of a gable using the method you mentioned? Is that what others have been writing about where they tuck the piece under the shingles?
go CATS!
Old 11-14-2007, 08:05 PM   #31
go CATS!
Yea. I put a crown in every board I make except my gutter boards and return back between the dripedge and shingles.
Go cats is right!
Siding: Aluminum vs. Vinyl Grumpy Windows, Siding and Doors 21 03-30-2010 08:02 PM
Fascia question Brushslingers Painting & Finish Work 5 04-04-2007 05:27 PM
Vinyl over aluminum? Sal616 Windows, Siding and Doors 6 02-20-2006 09:37 AM
What do you guys think of the big home builders? ruskent General Discussion 23 01-30-2006 09:08 PM
Need some feed back guys . . . Dually vs Single rear wheel. MEI MRG MM Vehicles 6 01-22-2006 03:21 PM
