How To Cut Vinyl Cedar Shake Siding For Addition?
Old 05-28-2008, 08:48 PM   #1
RomZes13's Avatar
Trade: Handyman
Hi!
I have a project to cut an opening and frame an addition for a fireplace in an existing wall. The opening I have to cut is 5x4' vinyl cedar shake siding. The frame needs to be 5x4x4.
I also have to pour foundation for the addition.
What's the best way to cut the siding?
I don't know if I have to screw wood into the siding before I cut so that it doesn't fall, and then frame and slide j channels in existing siding.
I'm also not sure of how deep the foundation should be. This is for a gas fireplace that does not need a chimney.
RomZes13 is offline
Old 05-28-2008, 09:35 PM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
Trade: Builder/Remodeler
Re: How To Cut Vinyl Cedar Shake Siding For Addition?
What works best for me is a battery skill saw or electric skill saw with a plywood blade ( they do make a fine cutting blade for vinyl siding it is thicker) install the blade backwards this way it will not chip or crack.
buletbob is offline
Old 05-28-2008, 10:01 PM   #3
RomZes13's Avatar
Trade: Handyman
Aha, almost forgot about this trick, thanks.
RomZes13 is offline
Old 05-28-2008, 10:08 PM   #4
buletbob's Avatar
YOUR WELCOME good luck
Quality is remembered long after the price is forgotten
buletbob is offline
Old 05-28-2008, 10:16 PM   #5
Patrick's Avatar
After you cut it I would slip in a piece of aluminum L bend the same color as the siding, then frame and sheath the addition, and install your J ON THE ADDITION butted against the old siding
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline
Old 05-29-2008, 02:14 AM   #6
Siding Windows Doors
easy sider's Avatar
Trade: Exteriors
To do the add on right you need to remove the vinyl cedar shingles off the wall and re-install them afer the addition is built.
easy sider is offline
Old 06-18-2008, 10:13 PM   #7
wellbuilthome's Avatar
Trade: building for 30 years. new homes , additions
I had to add a fire place bumpout to a addition after it was sided .I use a 4 " grinder with a cement blade .When i cut the sideing I like a porta-cable 315 trim saw with a cement blade and cut up on the pumps ,on the work bench.You could use a saw blade backwards with some soap on it ,or wax.
wellbuilthome is offline
Siding: Aluminum vs. Vinyl Grumpy Windows, Siding and Doors 21 03-30-2010 08:02 PM
Paint on cedar siding peeling. gideond Painting & Finish Work 19 05-03-2008 08:53 AM
log cabin vinyl siding Home Serve Windows, Siding and Doors 6 04-28-2008 08:16 AM
Watertight integrity of viynl siding? mci2980 Windows, Siding and Doors 71 11-24-2007 04:15 PM
cedar shake siding woodlover General Discussion 1 10-09-2007 02:06 PM
