HELP- Question On Door, Side Lite
Old 06-13-2009, 08:42 PM   #1
davinci's Avatar
Trade: roofing
how easy is it to just change the glass on a side lite? cutomer wants triple or double pane glass on old side lite.
they want to take the cheap way out.
davinci is offline
Old 06-13-2009, 08:48 PM   #2
genecarp's Avatar
Re: HELP- Question On Door, Side Lite
Depends on the type of door(brand). the age of the door. Every one is different. G
genecarp is offline
Old 06-14-2009, 10:39 PM   #3
katoman's Avatar
Trade: carpenter
Changing the glass in a sidelight is easy. Just pull the stops, change glass and re-install stops. Different thichness shouldn't be a problem.
katoman is offline
Old 06-14-2009, 10:43 PM   #4
solar guy
naptown CR's Avatar
Trade: solar contracting
If the sidelights are single pane check the rabbets to make sure there is enough room for the stops after ading additional glass thickness
naptown CR is offline
Question from lawyer trying to help contractor scp Business 52 02-25-2011 01:23 AM
Contract question MACEXCAVATING Excavation & Site Work 4 12-20-2008 09:24 PM
HVAC Licensing question kdan General Discussion 2 08-25-2008 09:17 AM
