Hardy Soffit Material - Anyone Used It?
Old 11-01-2007, 05:44 PM   #1
MHMConstruction's Avatar
I'm bidding a siding job and the HO's want new soffit too. They got a brochure at the Home Show that has Hardy soffit material.
I'm gonna bid the job - 84 lumber carries the stuff, or can get it the next day.
Anyone messed with this??? Any pointers or 'headache-avoiders' would be appreciated!
MHM
MHMConstruction is offline
Old 11-01-2007, 06:40 PM   #2
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Re: Hardy Soffit Material - Anyone Used It?
I have it in a subdivision I was the super for, I'm not overly impressed since there is no way to really conceal the fasteners.
Chris
Chris Johnson is online now
Old 11-01-2007, 08:00 PM   #3
kylemfk's Avatar
Trade: Supply
not a big fan. I distribute lots of hardiplank, i would recommend azek, koma or a primed pine before the hardi soffit. It doesn't rip nice, fasteners make a mess. I can tell you for every 100 Hardi jobs i sell maybe one includes hardi soffit.
kylemfk is offline
Old 11-02-2007, 02:15 AM   #4
marshallchad's Avatar
Trade: Commercial and Residential siding
Thumbs up
The wrong situation is on soffits less than 8" or over 24". We have hung thousands of square feet of hardi soffit. Some with hardi panel and a vent screen. A lot of the eaves we have used the vented hardi. It much cleaner, if you make sure to hang all of your soffit first before you side, that way the fasteners on the wall side of the panel are hidden. If you square up the nail and do not drive it too deep (6d ring shank), the head will clean up nicely. A two part epoxy (home depot or lowes) works well to concealed the fastener. Caulking doesn't smooth out as well and will gloss if it is not primed properly. Many won't prime, because it is already a preprimed product. Over all it is a clean, quick way to install soffits. For the cuts put them up against the wall and a nice touch is a 1x2 piece of cedar on the bottom edge. It helps hold the panel better anyway.
Soffits over 24" can be done, but you have more seams and doesn't look as clean.
marshallchad is offline
Old 11-05-2007, 10:11 PM   #5
Dan
ApgarNJ's Avatar
Send a message via AIM to ApgarNJ
I've used it before a few times and liked it. Used the power shears to cut it. if the edges get caulked cleanly, then you never see them. I tried their 5/4 trim before and hated it. I stick with miratech or azek for trim. hardie siding and hardie soffits are good though.
ApgarNJ is offline
Old 11-06-2007, 03:48 PM   #6
Yep I was wondering about the fasteners - what do you use, staples?
Plus, the overhang is big on some parts of the house (3') - maybe not a good idea.....
MHM
Old 11-07-2007, 08:43 PM   #7
Sophisticated Siding Guy.
thesidingpro's Avatar
Trade: Siding and Trim Specialist
I use staples when installing the hardie soffit.
I hate the stuff. Like someone said in this thread for every 100 hardie jobs I do maybe 2-3 use hardie soffit.
Don't even get me started on the 5/4 trim boards. I also hate them.
thesidingpro is offline
Old 11-08-2007, 04:44 PM   #8
sounds like a bad product
love the siding, though
Old 11-08-2007, 06:48 PM   #9
Bah Humbug!
Grumpy's Avatar
I haven't used the Hardy. I have used the certainteed. I don't use their vented product. I do use their 4x8 sheets and cut it to size. I usually install a 2" continuous vented strip.
Caulk and touch up paint on the fasteners. Installs using the same techniques as you would with cedar. We did cedar before fibercement was common in our area. Do more fibercement than cedar now.
I don't use fibercement trim boards at all. I prefer Miratec as my trim boards. Fibercement trim boards will flake a son of a... when you nail them , and also are very very prone to break while working with.
If you do a 3' overhang you are going to have to install rafter sleepers from the fascia board to the wall, on each rafter, and fasten your soffit material every 1' or so.
Grumpy is offline
Old 11-08-2007, 08:04 PM   #10
wannabe
WNYcarpenter's Avatar
Trade: carpentry
We use an 18 ga. finish nailer mostly (they hold pretty well), but we always apply wood trim against the house and along the facia we pre-drill and set maze siding nails here and there. Like hanging a drywall ceiling, the finish nailer tacks it up quickly and then you go back and secure it.
WNYcarpenter is offline
Old 11-21-2007, 09:55 PM   #11
losthenfound's Avatar
Trade: Roofing Siding Windows
We use a hidden eave vent and solid F&S. PVC - AZEK - KOMA - are nightmare thermal movers. We do not to use solid PVC unless at the ground, roof, etc.
PS You have to be a finisher also so counter sink - putty - paint
losthenfound is offline
Aluminum soffit estimate? K_Tile Windows, Siding and Doors 24 07-25-2008 11:56 AM
Hardy Siding bid MHMConstruction Remodeling 15 02-07-2008 09:32 AM
deck material smarks General Discussion 12 12-12-2007 03:59 PM
Material choice for fascia. kclapper Windows, Siding and Doors 5 07-31-2007 11:14 PM
Need Help With Hardy Soffit Pricing abelc Windows, Siding and Doors 1 02-20-2006 12:37 PM
