Hardiplank On Steel Studs
Old 11-04-2008, 12:49 PM   #1
jetfxr's Avatar
Trade: handyman
I'm replacing siding on a steel stud house. It's sheathed with gypsum board and has no house wrap. On cold days you can see the outline of the studs on the siding. I was going to wrap it but was wondering if anyone has used the foil/ bubble /foil thin reflective insulation such as Tekfoil or Prodex under Hardiplank? I would rather use it than putting up 4X8 sheets of foam as it comes in 8' x 125 ' rolls. Anyone have any input? Thanks
jetfxr is offline
Old 11-04-2008, 01:49 PM   #2
Restoration Crazy
Jason Whipple's Avatar
Trade: Restoration & Historic Preservation
Send a message via Skype™ to Jason Whipple
Re: Hardiplank On Steel Studs
You might want to consider stucco wrap, it's made for contact with cementious products.
How do you plan on fastening the siding?
Jason E Whipple, General Manager
Historic House Restoration, Cincinnati, Ohio
Facebook | Twitter
Jason Whipple is offline
Old 11-04-2008, 01:58 PM   #3
jetfxr's Avatar
Trade: handyman
I'm screwing it on with stainless self drilling screws. Both of the companies that I mentioned have products that can be used under siding., I was just hoping that I could find someone who has used something like that before. Thanks
jetfxr is offline
Old 11-04-2008, 02:11 PM   #4
Restoration Crazy
I can tell you right now that anything foil faced is not what you want to have in contact w/cement siding.
Facebook | Twitter
Old 11-04-2008, 02:54 PM   #5
jetfxr's Avatar
Trade: handyman
Thats why I'm posting to get input. What is the reason why you don't want foil next to cement siding.
jetfxr is offline
Old 11-04-2008, 03:28 PM   #6
Restoration Crazy
The chemical reaction between the concrete and foil could very likely eat through the foil in a short time.
Only galv. steel and S/S should come in direct contact with any concrete. No matter if its siding or a slab.
Facebook | Twitter
Old 11-04-2008, 04:11 PM   #7
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
1" of foam will help resolve the stud counting issue on cold mornings.
ET&F make a nail gun designed for fastening Hardi to Steel Studs.
Chris
Chris Johnson is offline
Old 11-04-2008, 04:31 PM   #8
Restoration Crazy
They work very well IME. I can't imagin screwing hardie siding on!
Facebook | Twitter
Old 11-05-2008, 01:44 PM   #9
jetfxr's Avatar
Trade: handyman
Thanks for your inputs, the reason I'm screwing it on is that the original siding was shot on with some kind of fluted nail and it wasn't holding very well. When removing the siding, most of the sections where coming loose and could be pulled off very easily. This happens to be my own house, I woulnd'nt do this job for hire for someone else.
jetfxr is offline
Old 11-07-2008, 05:20 PM   #10
Tenn sider's Avatar
Trade: Exterior remodeler
I have never heard of a gun to fasten to steel studs but bet I will be checking into it I had to screw hardi plank to a house that was formed to the roofline with foam cement forms then a pump truck filled with 8 inches of concrete. These forms had steel strips in them similar to steel studs. We used Stainless steel self tapping screws to fasten they did hold well but believe me it was no fun. You can use fan fold insulation under fiber cement it is reasonable cost and has a plastic coating that will not react with the fiber cement
Tenn sider is offline
cutting steel studs 25BRIAN General Discussion 28 05-22-2009 09:41 AM
Steel Studs in Bulkhead DSB_Const Framing 3 04-02-2009 03:12 PM
Condo's. hotels. When are steel stud's req'd? puke Commercial Construction 9 03-15-2009 04:09 PM
Hanging vinyl siding on steel studs. thesidingpro Windows, Siding and Doors 16 12-24-2008 06:38 PM
??? Whats the best way to spread the news about your company? jmgrahamjr Marketing & Sales 21 06-24-2008 04:46 AM
