Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Specialty Trades > Windows, Siding and Doors
Old 06-17-2008, 09:19 AM   #1
Trade: Contractor
Hardiplank installation rates
Can anyone tell me the going rate for hardiboard/plank installation per sq ft?
Last edited by Cole; 06-17-2008 at 09:40 AM. Reason: Moved to Windows, Siding and Doors
Hojosgal is offline   Reply With Quote
Old 06-17-2008, 09:23 AM   #2
Trade: home improvement contractor
I can do about 75 sf. an hour.
fourcornerhome is offline   Reply With Quote
Old 06-17-2008, 09:27 AM   #3
Trade: Contractor
Hardiplank rates
What do you charge per square foot to install hardiplank? What's that normal/average rate?
Old 06-17-2008, 09:30 AM   #4
demo master
kevjob's Avatar
you are not going to get solid answers, too many variables, how many LF how high is it, over a moat filled with crocodlies etc...
kevjob is offline   Reply With Quote
Old 06-17-2008, 09:33 AM   #5
Trade: Contractor
hardiplank
I was just trying to get a general $ figure on the going rate for hardiplank installation per sq ft. We aren't sure how to price the labor on this one. We do vinyl all the time......
Old 06-17-2008, 09:39 AM   #6
Mod / ArchiBuilder
Cole's Avatar
Trade: Design/Build Construction
Once again, too many variables.
IE: Where are you located?
How many sf can your guys install in an hour?
etc......
Midtown Tulsa Remodeling
Cole is offline   Reply With Quote
Old 06-17-2008, 09:43 AM   #7
Trade: Contractor
North Carolina
We've only installed it on quick fixes, repairs, etc. We are trying to bid on a job that is all hardiplank. So I guess there's not a "going rate" on the installation part of it?
Old 06-17-2008, 12:41 PM   #8
Trade: Consultant
Originally Posted by Hojosgal View Post
North Carolina
There's not a "going rate" for anything. Anytime you price your services based on what someone else is charging, you're setting yourself up for failure. Do you pay the same as what the other companies pay? Are your overhead costs the same? Do your crews work at the same speed as the other crews?
For example, let's assume your pay rates and overhead costs are the same as the "going rate" company (doubtful, but let's just assume they are). The only variable then becomes installation speed, and it's highly doubtful that your crew, which only does Hardiplank installations on "quick fixes and repairs" will install as quickly as a crew that does it all day every day. Therefore, if you charge the same rate they do, you'll lose your shirt, since your total labor hours will be substantially higher.
So, you need to figure out how long the job will take your crew, and price it according to that timeframe. Whether that gets you into the same ballpark as other contractors remains to be seen.
Bob Kovacs is offline   Reply With Quote
Old 06-18-2008, 06:03 PM   #9
Trade: Exterior Finishing
[quote=Bob Kovacs;453542]For example, let's assume your pay rates and overhead costs are the same as the "going rate" company (doubtful, but let's just assume they are). The only variable then becomes installation speed, and it's highly doubtful that your crew, which only does Hardiplank installations on "quick fixes and repairs" will install as quickly as a crew that does it all day every day. Therefore, if you charge the same rate they do, you'll lose your shirt, since your total labor hours will be substantially higher.quote]
For sure, unless your guys are subs in which case you can't subsidize them because they're slow, then the going rate where you are geographically and what type of installation is what matters.
Average pricing or the 'going rate' is all over the place when you ask guys all over north america.
From what I hear theres some competition in the states now as the work is slow so pricing is tight. Up here in Western Canada you just ask how much you would take for you to stretch yourself so thin and barely manage to get it all done in time... then add 10%
rojigga is offline   Reply With Quote
Old 06-18-2008, 06:25 PM   #10
Handle It!
MALCO.New.York's Avatar
$600.00 per linear board/foot/hour. This figure does not account for realistic mindsets nor feasible outcome projections unless duly noted heretofore by addendum, codicil or adjunct.
Ultimate Wisdom---------
http://www.youtube.com/watch?v=_k1Ug...ture=rec-HM-r2
MALCO.New.York is offline   Reply With Quote
Old 06-18-2008, 06:31 PM   #11
Trade: Registered (cough) Home Improvement Contractor
linear board/foot/hour....that comes out to an inverse square of opposite negitive unreal numbers!!! I didnt make in that far in math, please feel free to explain
Alwaysconfusd11 is offline   Reply With Quote
Old 06-18-2008, 11:41 PM   #12
Think it Draw it Build it
wallmaxx's Avatar
Trade: WA STATE GC Specialized in Structural Framing
the cheap guys up here start at $1.60 /LF @ 7" reveal to install.
WallMaxx, Inc.
Think it. Draw it. Build it.
Gun control is like trying to reduce drunk driving by making it tougher for sober people to own cars..
>>>>>libertas<<<<<
wallmaxx is offline   Reply With Quote
Old 06-19-2008, 01:34 AM   #13
Sounds like I and everyone is going to move to Washington because over $ 285 a square seems like a steal and a half as a sub... and I ain't no cheap guy, so I should be charging $350? $400?.
Old 06-21-2008, 03:13 PM   #14
brutis's Avatar
Trade: siding soffit hardie Tampa Fl
base your rates on say vinyl siding , on this forum some have said 95 or 110 a sq, so hardie is more involved takes longer and is heavyer and takes twice as long to do, my last job i went with 150.00 not enough , next time it will be 2.00 or not at all,
you can't base it on your exsperance if your a pro or not an it takes you longer, that is not a varible it dose not come into play, as for as priceing it dosen't matter if you do it by yourself or your a pro and have 10 man crew the price per sq. is the same , what can come in to play is height and cutup stuff , if your not a pro. you can shoot for more money but don't exspect it because of that.
be glad to get the job so as the next job you will have more exsperiance
brutis is offline   Reply With Quote
Old 07-18-2008, 11:45 AM   #15
If one gets 200.00 to 250.00 per square what is the charge for running the trim board as well? Or is that included in your estimate? I have a house w/500 pcs. of plank. And approximately 1500' of trim, once the freeze boards and window wraps, and corners are included. Any thoughts on this matter? Thanks, dawg
dfull05 is offline   Reply With Quote
Old 07-18-2008, 04:13 PM   #16
Rock it...
BattleRidge's Avatar
If they are normal height corners I got 15 bucks a corner for labor and 20 a window for labor. These are basics tho, somejobs are different then others, I don't do a boardfoot for trim usually I just kinda think how long it will take then put down a number.
BattleRidge is offline   Reply With Quote
Old 07-18-2008, 04:17 PM   #17
Plumber / Carpenter
Bill's Avatar
Trade: Virginia Building and plumbing contractor
Send a message via Yahoo to Bill
I hate those dang alligators
they keep getting in the way!
Is it beer thirty yet
Virginia Department of Licensing
Virginia Plumbing Codes
Bill is online now   Reply With Quote
$199 Carpet Installation For Your Entire House. Celtic Flooring 68 06-28-2009 08:09 PM
Exterior Door Installation BoydS Remodeling 59 02-20-2009 04:54 PM
Solar Power Industry Dead In California w6ire Electrical 2 06-28-2007 08:57 AM
Installation costs? dennyc Carpentry 2 06-10-2006 10:09 AM
Question about man hour rates Dorman Painting Painting & Finish Work 9 05-03-2006 06:35 PM
