Hardie Volcanoes
Old 07-02-2009, 08:39 PM   #1
Grand Rapids Remodeling
Paulie's Avatar
Hardie Volcanoes
I've got a question about Hardie board. I've always used a trim nailer for hanging Hardie trim but I ran across a job that the installer used a framing gun! Question: is there a putty that is exterior grade meant for Hardie? The guy wants me to caulk and paint the job but I think the caulk will leave volcanoes in the large nail heads. Any idea's?
Paulie is offline
Old 07-07-2009, 04:20 PM   #2
Siding Windows Doors
easy sider's Avatar
Trade: Exteriors
Re: Hardie Volcanoes
We have used grout to hide cracks and blowouts on cement board.
easy sider is offline
Old 07-07-2009, 05:28 PM   #3
topsail's trimcat
woodworkbykirk's Avatar
we use stainless steel ring nails in a coil nailer, blind nailed, if we have a large house to do the coil framer comes out as well blind nailed!! however when putting on closer pieces at the soffit we use a 15 gauge with stainless steel
for filling blow out we usually just use the color match caulking
woodworkbykirk is offline
Old 07-07-2009, 05:35 PM   #4
Sophisticated Siding Guy.
thesidingpro's Avatar
Trade: Siding and Trim Specialist
You guys are vicious using caulk to patch stuff.
You need to use an actuall patching compound and then touch it up with color matched paint.
MH Ready Patch I believe is the name of the stuff I use and is found at HD.
thesidingpro is offline
Old 07-07-2009, 05:37 PM   #5
Custom Stuff
Mike(VA)'s Avatar
Trade: General Contractor - Custom Renovations
Paulie, I hope you are using SS trim nails since standard interior trim nails will be corroded by the cement. Hardie will not honor their warranty if trim nails are used for that reason as well as the fact that they aren't strong enough. Best to use the nails they recommend. That said, I have used Drydex prior to painting. It is easy to shape to match cedar mill and sands easily. Did that 4 years ago on a job and today still no problems as long as the planks are properly painted.
__________________________________________________ ___________
I EXPECT THAT SOMEDAY I WILL SEE THE FRUITS OF MY LABOR. IS IT SOMEDAY YET?
Clifton, Great Falls, McLean, Fairfax Station, Manassas, Virginia Renovation Contractor
Mike(VA) is offline
Hardie repairs siding guy23 Windows, Siding and Doors 32 06-12-2009 09:57 AM
Hardie soffit fascia Precisionedge General Discussion 10 04-15-2009 10:04 AM
Attaching Hardie to Steel Studs Out-Sider Windows, Siding and Doors 2 02-26-2009 01:26 PM
Another hardie panel question? dkillianjr Windows, Siding and Doors 2 12-08-2008 11:31 PM
hardie plank reno questions hansolo1 Windows, Siding and Doors 2 08-03-2008 02:20 PM
