Trade: siding
Hardie Repairs
I don't have that much experience with Hardie, Mainly vinal. I have to go fix some hardie that has blown off and some dammage pieces. What is the best way to get the old piece out without breaking the next piece above? Can i face nail with my 16 gauge nailer? Will this hold? Why would the hardie blow off? the only thing I can see thats wrong with the install is that the nails are angled like he was trying to push the board tight to the next. Some of the boards are really loose and the HO complains they make noise in the wind. Does Hardie always give this much trouble and if so why do people think it is so great?
Not my work but it's up to me to fix it. |
Trade: siding
Re: Hardie Repairs
whats the exposure? whats it nailed too? it should be the studs,you could use a slate ripper or carefully cut the nails with a hacksaw blade.careful of the wrb
#3 | |
KemoSabe
Re: Hardie RepairsQuote:
__________________________________ "Walking the fine line between production and perfection" __________________________________ Last edited by loneframer; 08-15-2009 at 06:56 AM. |
Trade: Framing,Remodeling,General Contractor
Re: Hardie Repairs
Is that the pre=finished?
NKLHD |
Trade: siding
Re: Hardie Repairs
7" exposure and the nails pulled through the siding. There is lots of nails in it (every 10" i would say) Maybe shot too deep?
Re: Hardie Repairs
Read the instructions. That is what I did.
NKLHD |
Trade: siding
Re: Hardie Repairs
Instructions don't say much about repairs. Its my experience that the guys that install this stuff everyday have more knowledge anyway. It seems that if you try to remove one piece you end up damageing about 3 more.+/-
Trade: siding
Re: Hardie Repairs
could be too deep what kind of nail? ringshank? roofer? see every 10'' sounds to me like the studs werent marked and nailed into,
other installers say you dont have to stud nail but i always do Last edited by Tom Struble; 05-04-2009 at 08:38 PM. |
KemoSabe
Re: Hardie Repairs
Yup, 2002, this pic was taken in '07. Still looks nice. It was topcoated after install also.
__________________________________ "Walking the fine line between production and perfection" __________________________________ Last edited by loneframer; 05-04-2009 at 08:36 PM. |
Trade: trim carpentry
Re: Hardie Repairs
I've had success when removing pieces by prying out at the bottom and wiggling the piece until it breaks free from the nails. then gently pry the above piece out enough to cut the nails with dykes. you have no choice but to face nail the new piece back in though.
back when I was framing we used the flush tip for the framing guns when nailing hardi. keeps the nails from going to deep |
Re: Hardie Repairs
I hate that stuff. It should be face nailed.
NKLHD |
Re: Hardie Repairs
10" spacing sounds like mentioned already, not into studs.
How far from the top edge are the nails? 1" or something like 1/4". If the nails are too high like 1/4" from top, then I could see why the siding is flapping. As for removing try getting a wood block, lay it under the siding and give it a good whack with a hammer up. The siding is fairly brittle and this should get it to crack where the nails are. Then just pull it down and remove any left over pieces and cut the nails. Also cut the caulking before doing this. |
| The Following User Says Thank You to Kgmz For This Useful Post: | Tom Struble (05-04-2009) |
#13 | |
Coming out of the closet
Trade: Closet Design-Install-Remodel
Trade: Exteriors
Re: Hardie Repairs
The best way to remove a damaged board is like mmike032 said lift from the bottom of the board gently prying it in and out and it will break free from the nails... Hardi should always be nailed to studs no matter what.improper installation is the killer. you should nail 1" from the the top of board to keep a tight lap
Here where I live we also have a rainscreen system that gets installed prior to exterior which is stud nailed......... makes it quick and easy to find your stud |
KemoSabe
Re: Hardie Repairs
Ultimately I would use a coiled siding nailer with stainless 2 3/8 ring shank siding nails.
__________________________________ "Walking the fine line between production and perfection" __________________________________ |
| The Following User Says Thank You to loneframer For This Useful Post: | ClosetPro (05-05-2009) |
Sophisticated Siding Guy.
Trade: Siding and Trim Specialist
Re: Hardie Repairs
How many threads have you posted those pics in loneframer? Little proud of yourself?
| The Following User Says Thank You to thesidingpro For This Useful Post: | jcalvin (06-10-2009) |
Re: Hardie Repairs
Here ya go.... this is what we use
#18 | |
KemoSabe
| The Following 2 Users Say Thank You to loneframer For This Useful Post: | nEighter (06-11-2009), rbsremodeling (06-10-2009) |
#19 |
Capra aegagrus
Re: Hardie Repairs |
| The Following User Says Thank You to Tinstaafl For This Useful Post: | loneframer (05-05-2009) |
#20 |
Trade: siding
Re: Hardie Repairs
Well i did those repairs today. It seemed that for every piece i changed a couple more had to be changed in the process (I guess i got a little to "rammy"). It seems that the Hardie gets even more brittle over time. Looking around the one house I think i will have more work to do before the builders one year warranty is up. rggg. By they way the 10" spaceing was a "visual measeurement" it may have been every 8" hitting every other into a stud. The fact still remains that the nail didn't pull out of the wall, it pulled through the siding. It was half way up the wall on a 3 story walk-out and with no shelter break it gets really windy. Spiral shanked siding nails were used. I don't know if such a thing exists but to me a ring shanked, coil roofing nailer would be the thing to use with a bigger head, it would be tougher to pull through.
| Attaching Hardie to Steel Studs | Out-Sider | Windows, Siding and Doors | 2 | 02-26-2009 01:26 PM |
| Roof repairs in the frozen northwest | cowboyremodeler | Roofing | 12 | 02-03-2009 09:26 AM |
| No More Remodeling/Just Service & Repairs | Mr. Wms | General Discussion | 23 | 01-04-2009 06:17 PM |
| Another hardie panel question? | dkillianjr | Windows, Siding and Doors | 2 | 12-08-2008 11:31 PM |
| hardie plank reno questions | hansolo1 | Windows, Siding and Doors | 2 | 08-03-2008 02:20 PM |
