Hardie Plank Reno Questions
Old 08-03-2008, 01:42 PM   #1
hansolo1
Guest
hansolo1's Avatar
Posts: n/a
I am trying to put hardie plank siding up on a 1968 house. Contractors will do the work and I want to make sure its done properly.
The job involves stripping two layers of old siding off to get to plywood sheathing. The plan is to put rigid foil covered styrofoam insulation (1" thick according to hardie instructions) on top of the sheathing and then tape the seams. Then the hardie plank will go over this. Obviously the hardie should be nailed into the studs. Is there a good way to keep track of where these studs are after the insulation goes on? I would imagine this is critical info.
3 Windows were built out to accomodate the 1" inulation and hardie and some blue skin membrane about the window opening was left partially unadhered so that it could be integrated into the siding job. The idea was to stick this membrane to the outside face of the foil-backed insulation. Another option would be to stick it to the plywood sheathing. Any comments welcome.
One thing that was not planned was any type of building paper or house wrap. I was wondering if this would help or hinder the whole thing. The weather here is northern Alberta (extreme cold long winters), I wouldnt want to trap moisture/condensation somewhere and end up with rot problems.
Any comments much appreciated.
Old 08-03-2008, 01:55 PM   #2
Patrick
Guest
Patrick's Avatar
Posts: n/a
Re: Hardie Plank Reno Questions
Your siding contractor should be able to figure that one out for you.
Old 08-03-2008, 02:20 PM   #3
AtlanticWBConst
Guest
AtlanticWBConst's Avatar
Posts: n/a
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer if you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractor's to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at www.DIYChatroom.com If your not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.DIYChatroom.com/register.php/
We apologize for any inconvenience that this may have caused. This thread has been closed.
Nathan
Hardie Plank (per square rate of installation) jimetime Windows, Siding and Doors 44 05-14-2011 03:18 PM
Painting Hardie Plank BonitaBuilder Windows, Siding and Doors 9 07-01-2008 04:51 PM
Questions on 1st time Hardie. billderboots Windows, Siding and Doors 11 03-17-2008 05:00 PM
Hardie Plank Siding ApgarNJ Contractor Swap 0 11-05-2007 10:15 PM
Hardie Plank? CoastalCoatings Painting & Finish Work 14 03-10-2006 10:52 PM
