Hardie Plank (per Square Rate Of Installation)
Old 05-25-2008, 10:56 AM   #21
chris bellotti's Avatar
Trade: General Contractor, custom homes
Re: Hardie Plank (per Square Rate Of Installation)
NEED INFO PLEASE,
was always a cedar and pine guy, but now I'm doing my own house in Hardy.
How much waste on a typical colonial, not inc. gables?
What about Hardy shakes on gables, and how much waste?
What's the best cutting and shaping blades or shears out there, and where can I buy?
ANY INFO WOULD BE APPRECIATED!
chris bellotti is offline
Old 05-25-2008, 12:51 PM   #22
Dan
ApgarNJ's Avatar
Rewards Points: 2,000
Send a message via AIM to ApgarNJ
I use a circ saw with hardie blade for straight cuts, but for custom fitting cuts i use snapper shear brand shears.
some other guys can chime in on the waste factor for shakes because i haven't used the hardie shakes. I usually do 10-15% waste factor for plank siding.
hope this helps.
ApgarNJ is offline
Old 09-30-2008, 12:43 PM   #23
brob1969's Avatar
Trade: Certified General Contractor
I'm in Florida and we blind nail the planks with a roofing nailer then come back with a finish nailer and hit the boards about every 4 feet. Once painted you don't see the finish nails at all. Makes for a tight install.
brob1969 is offline
Old 10-06-2008, 02:58 PM   #24
bobaganoosh's Avatar
Trade: Exteriors
Hardie pricing is based on the exposure. It takes the same amount of time to put on a 4" exposure piece as it does a 8" exposure piece. Therefore we pay $12 per piece of hardie which is $3 per square foot for 4" exp. and $1.5 per square foot for 8" exposure. Wood trims, building wrap, flashings, strapping, and soffits are all separate prices.
Note: the above is labour only. Insurance, materials, taxes and markup are extra.
bobaganoosh is offline
Old 02-27-2009, 03:48 PM   #25
RED HORSE 554's Avatar
Trade: Project Manager and Builder
Rewards Points: 75
James Hardie product, cost $3 to $3.25 a square foot and the labor cost should be close to the cost per sq ft finished plus paint
RED HORSE 554 is offline
The Following User Says Thank You to RED HORSE 554 For This Useful Post:
kellyco (02-10-2010)
Old 03-04-2009, 03:31 PM   #26
looking for work
sideing's Avatar
Trade: roofing/siding
Send a message via MSN to sideing
Originally Posted by jimetime View Post
Help!! The blunt question is: What is a reasonable "price range" for the per square installation cost of hardie plank or other comparable cement siding? (either as a contractor or as what you might pay a sub to do it for you)
The sample base is a newly constructed 2 story, split level entry, deck in front and back, normal windows and doors home on the north-central Oregon coast.
Realizing there are so many variables can anyone tell me how the cost of putting on hardie plank compares with other siding applications such as cedar lap siding, T1-11, cedar shingles, vinyl siding, etc.
One other criteria - - do any of these costs include window wrap, corner boards, soffitt installation, or whatever else? What is the standard norm?
Thank any/all of you so much for any input.
If it were me depending on the build or house you are looking at a buck sixty per square and thats not including trim or envalope thats a good starting price then every thing else starts from there
sideing is offline
Old 03-04-2009, 03:41 PM   #27
looking for work
sideing's Avatar
Question
Originally Posted by chris bellotti View Post
NEED INFO PLEASE,
Hardie shake is a good product easy to use there are only three sizes so its easy to make a pattern so you keys dont line up and minimal waist i would say maybe 10% best tools would be a makita skill with hardie blade makita seems to be the one with the best bearings and 10 inch compound chop saw by the hitachi blades they last the longest and stay sharp you can get them perty much any matirial store even home depot has them dont like the shears very much slow cant do rips and knotches if you are good with a saw works the best bin doing hardie and siding for many years hope this helps
sideing is offline
Old 05-10-2011, 06:25 PM   #28
GCDan's Avatar
Fiber cement siding requires more planning, a larger work force, and takes longer to install due to its weight and composition.
Fiber cement siding weighs about 300 pounds per square, compared to 60 to 70 pounds per square for vinyl siding.
Moving this stuff is hard work and you don't want to move it more than once.
You need more employees on the job to move and support the boards as they go up and cutting them is time consuming
which will drive your labor and installation costs to double or triple the cost of installing vinyl siding.
As compared to a vinyl product of similar cost the cost with installation should be 40% to 50% higher.
According to my James Hardie sales rep, the national average for contractors who install Hardie Plank is $900 to $1,000 per square including soffit and trim.
As always there are guys who are looking to make a days pay and give the job away, many of these guys pay employees as 1099 subs without workers comp., taxes and FICA, carry minimal insurance and may even use undocumented laborers.
You can't operate a business for profit, carry all the proper insurances, bonds, workers compensation and do this work on the cheap.
Just for sh*ts and giggles:
Hardie Plank Color Plus cost: $150 per square
Tyvek Cost: $100 per square
3 men installing 3 - 4 squares per day: $750 = $215 per square
(in NY workers comp. alone cost almost $60 per man day)
Coil Nails, staples, Saw Blades, other equipment and materials: $55 per square
Total COST to contractor per square: $520
Add Overhead & Profit 30%: $156 per square
Your customer should pay: $676.00 per square
This DOES NOT include Soffit or Trim - add in the soffit and trim and you will be close to the national average of $900 - $1,000.
GCDan is offline
Old 05-10-2011, 06:27 PM   #29
GCDan's Avatar
Sorry 1st Post - Duplicated and can't DELETE
GCDan is offline
Old 05-10-2011, 08:02 PM   #30
Full Service Renovations
MAD Renovations's Avatar
I think they found the answer to this very OLD (years old)post!!
MAD Renovations is offline
The Following User Says Thank You to MAD Renovations For This Useful Post:
Dirtywhiteboy (05-10-2011)
Old 05-10-2011, 08:18 PM   #31
GCDan's Avatar
PERHAPS someone searching TODAY might appreciate a more CURRENT answer.
GCDan is offline
Old 05-10-2011, 09:42 PM   #32
hammer 689's Avatar
Trade: general contractor
Rewards Points: 83
about 600 a square for me.also i would like to add i never use a roofing nailer i prefer using a coil nailer with 2 and a quater shank nails because i dont think roofing nails hold well and they definetly dont get in the stud much wich is needed i think in my windy area and i face nail all but joints and edges against windows,corners etc. with stainless nails and as needed in the field if not laying down tight.
hammer 689 is online now
Old 05-10-2011, 10:04 PM   #33
GCDan's Avatar
Does that include soffit, trim and tyvek?
GCDan is offline
Old 05-10-2011, 10:20 PM   #34
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,677
Dan, the problem is that while your answer might be right on the money (pun intended) for you and your area, it can be way off the mark for someone in the next state or even a nearby community.
For that reason, these days we discourage throwing out numbers that way.
Tinstaafl is online now
Old 05-10-2011, 10:27 PM   #35
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
tyvek 100 a sqmust be that new gold plated tyvek
Tom Struble is offline
Old 05-10-2011, 10:30 PM   #36
hammer 689's Avatar
Rewards Points: 83
thats just a rough estimate for house wrap , siding and install only.no trim,soffit etc.there are a lot of variables as we both know so it really is hard to say.that is just a rough figure
Old 05-10-2011, 11:36 PM   #37
rock16's Avatar
Trade: Commercial Exteriors & Multi Family Remodel
Rewards Points: 274
I think your sales rep may be smoking something.
rock16 is offline
Old 05-11-2011, 01:47 PM   #38
welterweight's Avatar
Trade: sales
900-1000 per sq seems average. could be much more depending on the scope of the install.
guys coming in at 600 per sq is very suspicious to me and is a RED FLAG for shoddy work and a whole host of corner cutting. not to mention there is no profit.
welterweight is offline
Old 05-11-2011, 08:38 PM   #39
rojigga's Avatar
Trade: Exterior Finishing
Rewards Points: 152
I think is!
rojigga is offline
Old 05-13-2011, 12:31 AM   #40
contractorjay's Avatar
Trade: Roofing Siding Gutters Windows
Rewards Points: 250
chicago area
650 without window/corner
750 w/ window/corner
contractorjay is offline
whats the going rate per square apex Roofing 91 01-13-2011 04:45 PM
Hardie plank siding per square Snl Windows, Siding and Doors 16 02-10-2010 09:49 AM
Estimating paver installation rate mcgyverdc Landscaping 2 12-15-2007 07:34 AM
hardie plank install price? willbone3 Construction 10 05-10-2006 11:52 PM
Hardie Plank? CoastalCoatings Painting & Finish Work 14 03-10-2006 09:52 PM
