Hardie Over Cupped Shiplap
Old 09-28-2009, 09:38 PM   #1
pegasush's Avatar
Trade: Homebuilder/renovator
I am looking at my first Hardie install on a 100 yr old house. The house was sheathed with shiplap which has cupped. Renailing the shiplap flattens it some, but the wood is brittle, and generally cracks, and is still not flat. How much is this going to show through the hardie? How should the problem be addressed?
pegasush is offline
Old 09-28-2009, 10:06 PM   #2
solar guy
naptown CR's Avatar
Trade: solar contracting
Re: Hardie Over Cupped Shiplap
Do the client a favor
tear it off, insulate, sheath and tyvek and then put up the new siding
naptown CR is offline
Old 09-28-2009, 11:50 PM   #3
Official CT Greeter!
CScalf's Avatar
Trade: General Construction
ditto...
"Your problem does not constitute an emergency on my part"
CScalf is offline
Old 09-29-2009, 12:11 AM   #4
pegasush's Avatar
The owner had the building insulated previously when he reno'd the interior - insul, vb, drywall. I am sure I would not get a warm response if I suggest resheathing.
I have already stripped 3" of various siding materials. Hoping for a less drastic solution - furring strips?
pegasush is offline
Old 09-29-2009, 09:15 PM   #5
topsail's trimcat
woodworkbykirk's Avatar
did something similar this time last year, wasnt my call just installing. i wanted to strip off the old, gc said just strap and side. i said hes gonna get a callback
curious as to how the house is holding up...
woodworkbykirk is offline
Old 09-29-2009, 09:22 PM   #6
knucklehead's Avatar
Trade: Framing,Remodeling,General Contractor
Do you mean the shiplap is directly on the framing?
knucklehead is offline
Old 09-29-2009, 09:26 PM   #7
Sean
SLSTech's Avatar
You can strap it (you need to make sure its plumb with no waving), but I agree with the resheathe
I would present both options to the HO under the good, better, best options
SLSTech is offline
Old 09-29-2009, 10:08 PM   #8
pegasush's Avatar
Yes the shiplap is directly on framing - old fir studs, hard as hell.
Had another go today at tightening the sheathing. Used a sheathing stapler, 2" legs. Worked a lot better at pulling the shiplap tight and holding it, but still far from flat.
Furring - what to use? I read one thread where everything down to a doubled strip of felt has been advocated. I was thinking of using 3/4 x 3" strips of ply - too much, not enough, or just right?
pegasush is offline
Old 09-30-2009, 08:54 PM   #9
Javelin350's Avatar
Trade: James Hardie Hardiplank siding Gold contractor
My Crew and I have ran into this problem before with an older house. What we did was rip down a few 2 inch rips of hardie for shims, then take your chalkline and put it flat on the wall to see what studs need to be shimed out. The hardie will float the bow in the wall. One bad thing about hardie is it will very easily show thw bow in the wall.
Javelin350 is offline
Questions about Hardie Shingles Shocker00 Windows, Siding and Doors 17 08-26-2009 09:29 PM
Vinyl and Hardie Installation timm Introductions 7 07-11-2009 01:37 PM
Hardie volcanoes Paulie Windows, Siding and Doors 4 07-07-2009 05:37 PM
Hardie repairs siding guy23 Windows, Siding and Doors 32 06-12-2009 09:57 AM
Attaching Hardie to Steel Studs Out-Sider Windows, Siding and Doors 2 02-26-2009 01:26 PM
