Trade: windows-siding
Hardi Board/fiber Cement Install Question
this product is new to me as far as installation goes.i am actually going to install it on an investment property so if we mess up,we can just re do it. my question is this;does fiber cement expand and contract like vinyl siding?
i would imagine it gets nailed in all the way using a nail gun? do any of you guys use insulation board under the fiber cement? before you come down on me for starting a project i am not familiar with,its my property so what better way to learn! |
Trade: General Contractor, Remodeler
Re: Hardi Board/fiber Cement Install Question
1/8" gaps between planks and caulk. (I cheat it down a little so it looks better, but 1/8" is what the manu. calls for) Nail it tight, and no ins. underneath. 7d siding nails gun nailed work best for me, never staple it. Roof nails work ok, but sometimes if you shoot too low, you see the nail head.
now i am scared for my future i've got all ten smashed a lot of them stupidly before -john5mt |
Bah Humbug!
Don't forget to slide some metal or felt behind the gaps before caulking incase the caulk ever fails.
Nail guns are fine if it's shooting a small shank ring nail. Hot dipped galvanized are good. Don't use insulation IMO. It'll look too to wavy. Go get the installation manual from James Hardie and Certainteed Weatherboards. |
Trade: Exterior remodeler
Fiber cement does expand and contract but not like vinyl at all only somewhere less tha 1/8" I agree, deffinately put a piece of coilstock behind the seam leave1/16" to 1/8" between boards. When we use prepainted fiber cement we do not use caulk between joints just a 4" piece of coil stock, you can not see it when done. We had problems with the color matched caulk James Hardie supplied not matching up just right especially after a few months. If you are using a primed board product you can caulk with a good siliconized acrylic caulk then paint over. Hardie and certainteed are now requiring a full head ring shank hot dipped galvanized nail that has to be 1 1/4" into a stud. We use a duofast gun specifically for siding with a 1 7/8" nail. The guns and nails are spendy! We do sometimes use a ridgid fanfold insulation under fiber cement and have no problem with waves as long as the substrate is good and flat.
Go to certainteed fiber cement they have a good instruction manual C ya
Trade: green building
I use the woodgrained textured boards so that caulked butt joints are less noticeable. To do that, I brush the caulk in line with the wood grain using a nylon bristle brush. After painting, they are barely noticeable. I try to blindnail but on sides facing the usual direction of storm winds, unless those places are particularly visible, I will often nail the bottom edges also. I shoot hot dipped galvanized nails with my framing gun (using a soft tip attachment to keep from scuffing the boards). I keep the pressure low in the gun. Sometimes nail heads stick up and I have to finish them with the hammer, but that's better than overshooting and damaging the material.
Great product with the exception that you should nail 1" from the edge. That makes it a little tough to hit a stud @ 1-3/4".
Trade: Exterior Finishing
Don't leave a gap. Go tight. Gap will form no matter how tight.
Smart phone? Scan me!
Trade: Painting/Framing/Drywall
and use elastomeric caulking not siliconized.
Good point about corners, Teeterbilt. For the ends of the boards I either pre drill and hammer manually, or else I skip the nails altogether and rely on clips to form the butt joint without any fasteners
Trade: Exteriors
Field joints should be light to moderate contact as Rojigga said they will serperate a bit over time
Sophisticated Siding Guy.
Trade: Siding and Trim Specialist
Light contact on field joints has worked for me from day one. I would never caulk the field joints. 5 years later the caulk looks horrible.
I've never had a problem with bulging field joints. Most likely the ones that do are installing them to tight in the first place. |
In my experience the moisture content is at its highest when being installed. I have never seen this bulging over time unless like thesidingpro mentioned the install was originally too tight to begin with. Like I said, I have only ever seen hardie shrink; if it has expanded the siding shows no ill-effect from it.
LetItBe, we have to follow to the letter to meet Miami-Dade High Velocity Wind Code.
On my test house, mine, I replaced the gable ends (the most common job around here). I cut to fit, primed all sides with BM oil-based primer, installed w/ construction adhesive leaving a 1/16" gap, filled the gaps with BM's best exterior caulk and painted 2 coats of BM's best exterior paint. My house faces east, the south side gets FL sun all year and the north side none at all. This was done after Francis, son of Ivan and Jeanne hit in 2004. Wilma tested it the following year, it still looks great. I continue to install this way with zero complaints.
Trade: home construction
can you tell me the going rate for installation of hardiplank
Home Depot aisle walker
Trade: home remodeling
Re: Hardi Board/fiber Cement Install Question |
#16 | |
Re: Hardi Board/fiber Cement Install QuestionQuote:
Are we talking cement boards or sheets? This is the first I've heard of using any kind of glue with cement board lap siding. Please tell more. |
#17 | |
I have to say I agree. Also be aware of the tempature when you install. If installing in July in the sun, but the joints tight, the material will be at max dimension and will shrink in the winter months. I put 23 square of 6 1/4 on my house and the joints still look great. I places slip sheet behind and caulked with Geocel 2300 color match. The south side of the house still looks like the day I installed it. |
| Contractor law question for california contractors | saucedo80 | Painting & Finish Work | 7 | 04-18-2009 01:07 PM |
| Answer a Question with a Question | Nathan | Off Topic (Non Trade) | 151 | 10-07-2008 03:07 PM |
| Transitioning drywall with cement board | Lone Wrencher | Drywall | 19 | 03-02-2008 07:05 AM |
| Question About Hardi Lap Siding Installation | slbrown | Windows, Siding and Doors | 19 | 05-08-2006 02:18 PM |
| fiber cement install pricing | red_cedar | Windows, Siding and Doors | 15 | 04-08-2005 03:14 PM |
