GC/ Master Electrician
Garage Door Openers
Anyone know of a direct drive door opener thats not made by wayne dalton? Have a customer the want's 2 replaced but dosent want the wayne dalton ones again for some reason.
TIA
Ken |
Re: Garage Door Openers
Are you talking about the 'I Drive'? That's the only one I know about. Why are they so against that brand? I've installed 3 in the past couple of years, with no callbacks. I'd sorta like to know if they are failing in the field, so that I don't install any more.
(Consequently, remember when NuTone still made garage door openers? Those were the days. They made tons of stuff people would have never thought. Built in blenders. Built in bathroom scales. etc.) |
#3 | |
Re: Garage Door OpenersQuote:
Hope I find something I know of a nice garage door that would love to have the working one on it.
Ken |
The Amish use ones like these, since compressed air is okay: http://www.globalspec.com/FeaturedPr...umatic/27007/0
Just in case you need more search terms... In the most generic speak, the traditional garage door opener that hangs down in the middle is called a "trolley opener" and the one that mounts to the side of a commercial torsion spring door is called a "jackshaft opener". |
Trade: Electrical
They make some now that mount on the header and the shaft goes through it, assuming she has a sectional door. My father in law is a garage door contractor and I will ask him who makes them and post later if you would like.
#6 | |
Thank's
Ken |
Do a google search for "liftmaster"...that is the brand my door supplier sells and the price isn't bad. I just ordered 3 today for the building we are working on...the 1/2 hp opener is good for the 24 wide by 16 high door we are putting up.
Trade: Commercial Loading Dock and Door Contractor
I just replaced 3 I-drives with brand new units, the originals were only 1 year old. the only way that the openers would work is with the doors a little on the heavy side.
It's a great concept but not as reliable as it should be. Try this link http://www.acd-usa.com/805series.html it is a commercial DC drive unit similar to the I drive, but is belt driven. If you go with any direct drive unit that attaches to the torsion shaft, you should make sure to include pusher springs see link http://www.garagedoor.org/commercial...art/RS-36.html to help the door into a vertical position as the door may not move as fast as the opener initially, and you need to keep tension on the cables. |
| Garage receptacle | ChuckEA | Electrical | 21 | 04-27-2011 07:45 PM |
| garage insulation | maderuyck | HVAC | 2 | 03-18-2007 12:43 PM |
| Flat roof over garage leaking under exterior walk out door | IHI | Roofing | 18 | 05-30-2006 10:28 PM |
| ...continued...garage floor drain progress | carlspackler | Plumbing | 0 | 05-27-2006 02:54 PM |
| Hot and cold water in the garage | Mike Finley | Plumbing | 18 | 12-06-2005 08:07 AM |
