Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Specialty Trades > Windows, Siding and Doors
Old 01-25-2009, 10:39 AM   #1
Trade: Modular Homes
Question Fypon J Channels?
Hey guys, one of my workers said he heard of buying fypon in sheets, ripping 1x4 trim boards and then rabbitt cut them to use as j channels. The 5/4 with a 3/4 rabitt sounds OK and it may look nice but never did it. Anyone ever done it? Hints? All responses greatly appreciated. Thanks!
fwgreco is offline   Reply With Quote
Old 01-25-2009, 10:59 AM   #2
tomstruble's Avatar
Trade: siding
havent heard fypon sheets but they have 5/4 a 4 with the rabbet cut aready i think maybe he meant pvc?
tomstruble is offline   Reply With Quote
Old 01-25-2009, 11:32 AM   #3
Thanks. Any special installing techniques? Do I have to use glue and nails or just nails?
Old 01-25-2009, 12:14 PM   #4
Trade: windows-siding
i am pretty sure you can buy fypon sheets with a j already built in to it. why fypon,buy some azek sheets. azek DEFINITELY come with a 3/4 inch j-pocket. azek does not have to be painted whereas fypon does and i also think fypon is more money. more importantly,azek is much more durable. you can also use restoration millwork from certainteed.
when using 5/4 sheets without j,just route out a j with a router bit.
enforcer is offline   Reply With Quote
Old 01-25-2009, 03:28 PM   #5
tomstruble's Avatar
Trade: siding
you could also pack out 3/4 stock the siding thickness.Whether you rout out or pack out you should install a metal drip cap to keep any water out of the window head
Old 01-25-2009, 03:59 PM   #6
Side windows are covered by eave so no sweat, but how would I install metal drip edge over rabitted aztek/fypon? I see your point and it's a good one, silicone will not hold up?
Old 01-25-2009, 04:02 PM   #7
The siding will be vinyl, so are you saying I should use one of those tight sill pieces on the top to hold the vinyl piece over the drip edge?
Old 01-25-2009, 04:43 PM   #8
tomstruble's Avatar
Trade: siding
i would and this is just my opinion
Tags
fypon, j-channels
Fypon Crown moulding brailediver Finish Carpentry 17 01-30-2009 09:21 PM
TV channels - who owns what you watch wallmaxx Off Topic (Non Trade) 1 10-23-2008 09:02 AM
opinions on FYPON enforcer Windows, Siding and Doors 3 10-06-2008 05:59 PM
Fypon Window Crossheads and Vinyl Dentil Amar Windows, Siding and Doors 2 03-09-2008 08:30 PM
Working with Fypon Guardi Pro Painting & Finish Work 5 06-04-2007 06:49 PM
