Flexible J-Channel
Old 11-01-2005, 09:53 PM   #1
Finish Carpenter
Bukemdano's Avatar
Trade: Finish carpentry
Flexible J-Channel
I have a major problem. I am using canyon clay siding and have an arched window. I cannot find any flexable J-channel in Canyon clay. Can you paint flexible J-Channel. I have paint that will match it perfectly... Any help would be greatly appreciated... Thanks
Dano
Bukemdano is offline
Old 11-01-2005, 10:17 PM   #2
Tom R's Avatar
Re: Flexible J-Channel
I just installed some Canyon Clay on an addition last month (Amherst brand??), - - their 'J' was a little larger than normal (which could work to your advantage), - - I doubt if paint would hold up too long on vinyl (too much movement), - - but I wonder if you could install 'any-color-flex' as your base, - - and then 'face-cut' your Canyon Clay 'J' for your front-piece, - - in other words, cut off the back and some of the bottom, - - just leaving the whole face and about the front 1/2" of the bottom, - - then cut slits every few inches or so along the bottom so it could flex easier. To attach, - - you'd slide it your bottom under your flex-J and then nail downward thru it with a pea-shooter.
http://www.tr-built.com
Tom R is offline
Old 11-03-2005, 10:48 PM   #3
Finish Carpenter
Bukemdano's Avatar
Excellent..... That sounds like a good idea...I will give it a shot... Thanks for the info.. I will let you know how it turns out
Dano
Old 11-03-2005, 11:10 PM   #4
Custom Builder
Glasshousebltr's Avatar
Good plan Tom.
Bob
Bob
Glasshousebltr is offline
Old 11-08-2005, 10:31 PM   #5
sidewaller's Avatar
Trade: siding
if you paint it it will work
sidewaller is offline
Vertical Cedar Channel Rustic.. RISENRUN Carpentry 2 06-20-2007 12:46 PM
Benefits...401K...Flexible Spending Accounts assembleinstall General Discussion 0 06-12-2007 01:50 PM
Flexible Foam Crown Molding pshammond Finish Carpentry 11 08-06-2006 11:53 PM
Flexible Black Poly Tube and ABS Fittings? theworx Plumbing 2 05-23-2006 12:49 AM
Flexible base shoe jeffkaprelian Flooring 5 03-22-2006 01:56 PM
