You can buy prebent flashing ( 3/4", 1", 1-1/8", 1-5/16" ) at the lumber yard in different colors. Or make your own.
If it's a flanged window (Andersen Permashield) Install the window to the sheathing with Vycor (ice & water) like you normally would, then apply the wooden casing and flash the head casing to the vertical, B&B. Make the casing 1-1/4"+ so the B&B has a shoulder to die into.
Remodeler in Maine & Vermont
Finish carpenter
Been doin' this stuff for a long time.................
