Finishing Threshold On Concrete - Windows, Siding and Doors - Contractor Talk
Old 12-04-2017, 08:24 PM   #1
goneelkn's Avatar
Trade: home remodel/repair
Rewards Points: 122
How do you guys finish the gap on thresholds when the concrete stoop slopes down. I've done caulk, but lately getting some bigger gaps(1/2" - 3/4") and caulk doesn't look good.
goneelkn is offline
Old 12-04-2017, 09:04 PM   #2
hammer7896's Avatar
Rewards Points: 162
Re: Finishing Threshold On Concrete
Iíve been using azek to fill spaces under doors
Mike
hammer7896 is online now
Old 12-04-2017, 09:10 PM   #3
FrankSmith's Avatar
Rewards Points: 4,966
I would think filling the back with foam and the front with mortar might be the best option
FrankSmith is online now
The Following User Says Thank You to FrankSmith For This Useful Post:
jhark123 (12-16-2017)
Old 12-04-2017, 09:46 PM   #4
goneelkn's Avatar
Rewards Points: 122
Do you taper the Azek like a big shim, or just fill the front?? Last few doors have had a large taper on the concrete causing bigger gaps.
Worried that mortar would just crack with footsteps over the years.
goneelkn is offline
Old 12-04-2017, 09:52 PM   #5
Jay hole's Avatar
Trade: General contractor
Rewards Points: 1,369
I have used the quickctete mortar repair with good results.
Jay hole is online now
The Following User Says Thank You to Jay hole For This Useful Post:
Metro M & L (12-21-2017)
Old 12-04-2017, 10:07 PM   #6
goneelkn's Avatar
Rewards Points: 122
How big of gaps have you done with that??
goneelkn is offline
Old 12-04-2017, 10:18 PM   #7
Jay hole's Avatar
I think I've gone up to 3/4" before, I didn't go back later to see how the big gap held up. But I've been back to see 1/4" to 1/2 beads months later and it still looked good. Obviously you want to make sure the threshold is properly shimmed so it doesn't flex.
Old 12-05-2017, 12:33 AM   #8
Safety Third
shanewreckd's Avatar
Trade: Concrete Cowboy
Rewards Points: 324
I had a project where we bent a flashing that slid under the threshold and covered that space. It wasn't my favourite solution, very annoying to install on 30 doors but it gave some attractive results. I like Jay's idea of the Quikrete product, although I would probably go more towards either the stucco repair or fast set repair mortar.
shanewreckd is online now
Old 12-05-2017, 07:12 AM   #9
Tom M's Avatar
Rewards Points: 7,728
The last entry door I installed I made a wood threshold with no slope to support the lip of the metal and extend to the brick mold. I still ended up with a good 3/8 gap that showed my spray foam. Not happy with that.
Not sure why. I really dont examine the bottom of the door like I should prior.
Tom M is offline
Old 12-05-2017, 07:27 AM   #10
TimNJ's Avatar
Rewards Points: 3,146
For 3/8"-3/4" I would cut a wood (or Azek) wedge.
The main thing is to make sure you are supporting the back of the threshold (inside edge) too. Otherwise the threshold collapses when ever the ho steps on it.
TimNJ is offline
Old 12-05-2017, 07:54 AM   #11
goneelkn's Avatar
Rewards Points: 122
The back edge is supported. There's a 2X in back of the concrete that sits directly under door slab. I do shim the rest out.
That flashing i thought of doing, does sound like a lot of work.
goneelkn is offline
Old 12-05-2017, 08:49 AM   #12
AustinDB's Avatar
Rewards Points: 840
I haven't seen a piece of Azek in 4 years! How deep is the projection from the concrete? Backerrod and NP1 was how I use to do this. The NP1 holds it's shape and is very workable with a finger dipped in mineral spirits.
AustinDB is online now
Old 12-05-2017, 09:31 AM   #13
dsconstructs's Avatar
Trade: Remodel Contractor
Rewards Points: 798
I typically use mortar for that. Fast/easy and gives support for the threshold from flexing when stepped on.
dsconstructs is offline
Old 12-05-2017, 03:35 PM   #14
goneelkn's Avatar
Rewards Points: 122
Varies with jam depth and slope of stoop.
goneelkn is offline
Old 12-05-2017, 04:44 PM   #15
Jay hole's Avatar
Pardon my ignorance, but what kind of mortar? Is it a bag of pre mix stuff?
Old 12-05-2017, 04:47 PM   #16
Rewards Points: 798
Bag
Old 12-05-2017, 06:30 PM   #17
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 2,262
If it were my decision I would put some beautiful stone down on the fugly concrete and make it pretty Superseal could make it look nice!
Otherwise I would cover that flashing with a piece of aluminum to match the aluminum sill plate. Depth could be adjusted. Box could be used. Weld up whatever is needed.
Peter_C is online now
Old 12-05-2017, 06:42 PM   #18
hammer7896's Avatar
Rewards Points: 162
Normally I would double up the Azek to get out to the edge of the threshold and taper it fit
Mike
Old 12-06-2017, 01:05 PM   #19
Lettusbee's Avatar
Rewards Points: 2,882
Attachment 420849
You're lucky, usually when I have to deal with it is 3/8" on the right to 1" on the left. Exaggerating mostly, but you get the idea.
I've used Backerrod and Sikaflex for the smaller gaps.
Cut pieces out of PT or Redwood for the larger gaps. Paint to match.
Also have use Non-shrink Precision Grout:
https://www.quikrete.com/productline...isiongrout.asp
Lettusbee is online now
Old 12-10-2017, 09:42 AM   #20
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 2,224
put a piece of matching aluminum under there and walk away
"Building trust one job at a time."
www.RDPontheWeb.com
San Diego Contractor Deck and Patio Cover Builder
parkers5150 is offline
Paslode V Bostitch Finishing Guns hemz Tools & Equipment 27 06-09-2015 11:04 PM
17-ton concrete slab overhang fell from a bank building in Stroud Township AmeliaP Masonry 27 09-05-2013 07:16 PM
Lightweight concrete alternative in a condo DanFreysinger Flooring 17 11-14-2012 10:10 AM
Concrete with Fly Ash vs. Concrete without? cdkyle Concrete & Paving 19 07-28-2010 09:57 PM
concrete walls finishing mjay Masonry 2 03-05-2009 03:36 PM
