Trade: windows-siding
Fiber Cement Siding Question---
normally,what kind of trim are you guys using around windows and doors?
are you using azek? whats the most common? what are you using for corners? does hardie have an actual hardie plank corner piece? do they hardie door and window trim? is each seam(where the butt joint is) get flashed under neath? thanks guys |
KemoSabe
Re: Fiber Cement Siding Question---
I've always used Azek or a similar pvc product. Miratec seams to be a valid choice for machinability and texture. Whatsay TomStruble?
__________________________________ "Walking the fine line between production and perfection" __________________________________ |
| The Following User Says Thank You to loneframer For This Useful Post: | Tom Struble (06-24-2009) |
Trade: siding
Hardi has it's own trim in several widths. It's called XLD. It's kind of a pain to work with.
It's better to die on your feet than to be living on your knees. |
i know it varies,what the most popular reveal? 5"? what kind of soffits are used? vinyl?
Trade: siding windows soffit fascia
How are you guys making long rips where wall meets soffit? All we have to cut with is a circular saw with a fibercement blade. I suppose a guide for the saw might work best but don't think we have one around. Are you doing any face nailing or screwing where the wall takes a bump or dip? (in order to pull the siding tighter to the wall to avoid a gap). Any shims or anything where the walls are off? I figure this would take a lot of messing around. We are using an air nailer and find it works well. Bostich. Thanks!
Missouri Remodeling Company with services for Replacement Windows Vinyl Siding and Entry Doors |
Sophisticated Siding Guy.
Trade: Siding and Trim Specialist
I use a 16g stainless trim nail to face nail.
The top rip my guys have no problem keeping it straight. On big jobs we have used a table saw. |
#7 | |
Re: Fiber Cement Siding Question---Quote:
I thought about bringing out the table saw to rip it also. Haven't seen any larger than circular saw fiber cement blades however. We sacrificed our miter saw blade today making butt cuts, the blade was kind of old anywho. When you say 16g?
Trade: Paint & Drywall
For my top row I was lucky to be going over some old barn type siding. We housewrapped it and then put it on. For the top row when it met the soffit we just used a trim nailer with some galvanized nails. No nail heads showed, they were small and sank, then we puttied them.
topsail's trimcat
most often cape cod for the corners and window/doors trim, azek for accent trim for porch soffit, fascia, and deck post cladding
for nailing closing strips of harti at the soffit we run a bead of clear caulk onthe back to act as sealant and adhesive then face nail with the 15 gauge nailer loaded with stainless steel 2 1/2"
putting down subfloor with glue and screws, well i saw dr. smith and the robot too , i had a martian burger and a sonic shake |
#10 | |
KemoSabe
All trim is Azek.
__________________________________ "Walking the fine line between production and perfection" __________________________________ Last edited by loneframer; 08-15-2009 at 06:53 AM. |
Trade: siding
The majority of my customers will only except cement trim (they tend to think they have to have cement trim if they have cement siding). We usually use a 4" around doors and windows, 6" for corners. We make all our rips on the table saw, including windows. Since hardi wants a 1/4" space above all dripcaps (not caulked), for us the table saw gives the cleanest, most factory looking cut. No one up here uses vinyl soffit except for trailer, modular, and prefab homes. Aluminum is used 90% of the time.
| The Following User Says Thank You to jumbo For This Useful Post: | Tom Struble (07-02-2009) |
Trade: siding
i like the head trim ,looks like its packed out 1/4 more than the rails ,nice
Tom |
| Siding Question | Paramount Contr | Windows, Siding and Doors | 11 | 12-10-2008 10:20 PM |
| Fiber Cement Board installation | davinci | Windows, Siding and Doors | 4 | 09-13-2008 10:21 PM |
| pricing fiber cement siding | jameshow | Windows, Siding and Doors | 7 | 04-13-2007 01:57 PM |
| Framing gun for fiber cement siding? | dantheman | Windows, Siding and Doors | 4 | 12-14-2006 08:34 AM |
| Question About Hardi Lap Siding Installation | slbrown | Windows, Siding and Doors | 19 | 05-08-2006 02:18 PM |
