Feedback On Corners With J Pocket
Old 11-14-2008, 03:22 PM   #1
swanee's Avatar
Trade: building and remodeling
Anyone out there used the corners or trim boards rabbited out in the back in conjunction with fibercement. Restoration from certainteed is what I am looking at although there are others I have seen. What kind of problems have you encountered? Are you applying caulk and pushing siding into it? They seem like a good idea for if nothing else they might hold down the butt edge of the siding and keep them in line. Thanks!
swanee is offline
Old 11-15-2008, 09:40 AM   #2
Patrick's Avatar
Re: Feedback On Corners With J Pocket
We use trim solutions out of CT awesome product and the nail fin is much better than any other product we have used. kinda pricey though at about $9.50/ft
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline
Old 11-15-2008, 09:00 PM   #3
swanee's Avatar
I am not sure we are talking about the same thing. What I am looking at is sort of like azek (pvc). There is no nail fin. There is a 3/4 by 3/4 pocket rabbited out of the back of the board.
swanee is offline
Old 11-16-2008, 08:01 AM   #4
Patrick's Avatar
This company takes 5/4 azek routs out a pocket, and then heat welds a nail fin to the back so that you get a real reveal on the face of the siding
Patrick is offline
Old 11-16-2008, 08:36 AM   #5
enforcer's Avatar
Trade: windows-siding
i am using a similar product from "advanced trim wright" out of mass. they route out a 3/4 inch j-pocket. we have to trim ours out using some insulation board in order to accomadate a 1 1/4 pocket needed when using cedar boards insulated siding.
enforcer is offline
Old 11-16-2008, 10:53 AM   #6
swanee's Avatar
That sounds very interesting. So does that mean you are not face nailing the corner at all? Also how are you caulking, before, after, or both?
swanee is offline
Old 11-16-2008, 02:34 PM   #7
Patrick's Avatar
NO face nailing. The heat welded nail flange is similar to that of a vinyl window with oval shaped holes. We install the corner over the building paper, and then we tape the seam with 9" window tape. we then apply a bead of caulking behind the siding as we go. If we are using vinyl, then we skip the caulking. They also make beautiful window trim that goes up nail less, all put together sized to any window.
Patrick is offline
Old 11-16-2008, 09:10 PM   #8
swanee's Avatar
Thanks guys this has been very helpful!
swanee is offline
TimberTech Composite (Earthwood) Installation - picture frame corners and HFS jackem Decks & Fencing 6 11-06-2008 04:05 PM
How many Pocket Doors are enough?? woodbutcher2004 Finish Carpentry 14 02-14-2008 07:47 PM
Question about inside corners Lone Wrencher Drywall 36 12-08-2005 07:37 PM
