Favorite Interior Caulk For Windows/doors
Old 03-22-2009, 06:09 PM   #1
davinci's Avatar
Trade: roofing
anyone have a specific brand or compound(silicone ect..) that they prefer?
davinci is offline
Old 03-22-2009, 06:26 PM   #2
advanced_energy's Avatar
Trade: windows-siding
Re: Favorite Interior Caulk For Windows/doors
The newest hybrids defy classification
Modified-silicone polymers.
Modified-silicone polymers like DAP’s Side Winder and OSI’s Advantage represent the newest type of sealant available. They are difficult to classify because they combine the chemistry and benefits of water-base, silicone, and polyurethane products into one sealant. They are expensive but worth the money for sealing important outdoor areas like windows, doors, and vents.
thesecan be used indoors and work extremely well. also,DAP Alex plus 35 yr is good for the money.
advanced_energy is offline
The Following User Says Thank You to advanced_energy For This Useful Post:
Tom Struble (03-22-2009)
Old 03-22-2009, 07:08 PM   #3
gallerytungsten's Avatar
Trade: Design
Top Gun 400 - lifetime warranty. Good stuff.
gallerytungsten is offline
Old 03-22-2009, 10:51 PM   #4
paul100's Avatar
Pecora ac-20
paul100 is offline
Old 03-22-2009, 11:01 PM   #5
Patrick's Avatar
we rarely caulk inside, if we do its just painters caulk
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline
Old 03-22-2009, 11:26 PM   #6
painter caulk for interior is almost a most;however,it must be of a high quality and contain some silicone or else it cracks.
Old 03-23-2009, 09:37 AM   #7
i'd be remiss in not mentioning this product...
XtraBond™9500
MODIFIED POLYURETHANE SEALANT
Description
XtraBond™9500 is a high performance, one component, permanently flexible, easy to use, multi-purpose fast cure modified polyurethane sealant. XtraBond™ 9500 cures rapidly when exposed to atmospheric moisture to form a durable bond.
Old 03-24-2009, 08:44 AM   #8
enforcer's Avatar
a very good indoor sealant is Dap's Dynaflex. this is sold at home depot and is highly recommended by my installer for interior use. can be used out door as well but we stick to Quad.
enforcer is offline
Old 03-25-2009, 08:04 AM   #9
President
Jake Stevens's Avatar
Trade: Installing windows, siding, roofing, doors, patio rooms, gutters and shutters.
What Patrick said. I find the only time you need to cauld inside is because you up the trim.
Jake Stevens is offline
Old 03-25-2009, 06:39 PM   #10
thats simply not true. there are instances where caulk is warranted and not because we ruined trim.
Old 03-25-2009, 11:17 PM   #11
grob62's Avatar
Trade: Windows and Doors
Sure sometimes you have to caulk when the opening is so out of square that the stops don't cover because you have it maxed out to opposite corners. Or when some shmuck of a install manager can't measure worth a poo. Or sometimes the HO just friggin wants it caulked.
Now for a question. I know quad is used on exterior, but is there any reason it can't be used on the interior. It is paintable and stainable, so what is the downside to using it inside?
grob62 is offline
Old 03-25-2009, 11:32 PM   #12
Patrick's Avatar
The risk of getting calls all night from the HO about the smell
Patrick is offline
Old 03-26-2009, 09:31 AM   #13
President
I guess I shouldn't judge other peoples work, we do thousands of windows every year and I'm sure we can count on one hand the number of windows that we might have to caulk on the inside. If its an old house, with out of square openings, sometimes we might have to shim out the back of the extension jams, out on to the window or even change the jams and in some cases just add on to them. Even on old windows that have alot of paint on the jams, we re-cut the side jams with the headed so that all the trim sets flat on to the window.
Old 03-26-2009, 11:14 AM   #14
Patrick's Avatar
yea for us its the one or two times a year when you replace those aluminum track double hungs that are only 3" or 3-1/8 thick and you cant put the stops tight to the window without exposing the old Jamb where the casing is.
More common, is the need for one bead where the stool meets the window.
Patrick is offline
Old 03-26-2009, 03:45 PM   #15
technically Quad can be used interior but the company highly recommends not doing that. why? the odor is powerful and can linger for days causing homeowners to get adverse reactions. in short, DO NOT use QUAD for interior use. as another poster mentioned, Dynaflex 230 is a ubiquitous product that seems to hold very well over time for interior use.
Old 05-09-2009, 01:03 AM   #16
poisgo's Avatar
Trade: windows siding
i caulk the inside of every window. why not?
poisgo is offline
Old 05-09-2009, 08:13 AM   #17
Handyman Jim's Avatar
Trade: Handyman,Doors,Carpentry
DAP Alex plus 35 year.
Handyman Jim is offline
Old 05-09-2009, 05:35 PM   #18
Error Corrector
olyteddy's Avatar
Trade: Maintenance Manager
I use Dap Alex Plus and the other Dap Latex caulks for most of my inside work. I like how it dries quick, paints easy and doesn't stink. Okay, it does smell a bit like Bananas...
When what you've got is a hammer
all your problems start looking like nails...
olyteddy is offline
Old 05-09-2009, 06:25 PM   #19
Capra aegagrus
Tinstaafl's Avatar
I use the Alex as well, but not latex-only. I've found that the paintable latex/silicone mix (in any brand) spreads much more nicely than latex-only.
And it leaves my hands silky-smooth.
And it tastes so yummy!
Tinstaafl is offline
Old 09-02-2009, 08:41 PM   #20
ssgtcarroll's Avatar
Trade: Glass/Doors
Sikaflex 15LM inside and outside...Commercial Windows.
ssgtcarroll is offline
What's your favorite faucets, etc. HWCostruction Plumbing 6 02-19-2009 07:45 AM
Favorite knockdown knife Tradesman Drywall 7 10-15-2008 09:57 PM
Hot sauce, what is you favorite Bkessler Off Topic (Non Trade) 29 10-01-2008 10:46 PM
Whats your favorite project? healthyhomes General Discussion 7 09-11-2008 01:40 PM
Favorite Standard Weight FrankT Roofing 2 08-19-2008 08:25 PM
