Fascia - Alternative To Aluminum
Old 10-07-2009, 03:49 PM   #1
JoeT
Guest
JoeT's Avatar
Posts: n/a
I'm looking for an alternative to black aluminum 10" fascia. Hardie not available in black..... Anyone have any suggestion? Compaint is 'wavey' appearance of aluminum. Needs to be available in Western Canada....
Thanks for any input!!
Old 10-07-2009, 04:23 PM   #2
Jake Stevens
Guest
Jake Stevens's Avatar
Posts: n/a
Re: Fascia - Alternative To Aluminum
How wide is the fasica? Maybe you can add a shadow board.
Old 10-07-2009, 04:33 PM   #3
JoeT
Guest
JoeT's Avatar
Posts: n/a
thanks for the reply!
sorry, not familiar with shadow board. I'm guessing it's a narrower piece applied on top of the flat face of the fascia.....
what about gutters if I guessed right?
Old 10-07-2009, 04:40 PM   #4
Jake Stevens
Guest
Posts: n/a
If you are installing gutters that's going to cover the aluminum and it's not going to oil can anyways. If not, it is a small board added on the top of the fasica.
Old 10-07-2009, 04:43 PM   #5
JoeT
Guest
JoeT's Avatar
Posts: n/a
ok, thanks again!
Obviously, I would then clad both in aluminum and this would prevent the oil canning.
Old 10-07-2009, 04:49 PM   #6
Jake Stevens
Guest
Posts: n/a
Originally Posted by JoeT View Post
ok, thanks again!
Yes, you should always try not to have more than 5" wide fascia.
Old 10-07-2009, 04:51 PM   #7
JoeT
Guest
JoeT's Avatar
Posts: n/a
Thanks again Jake, all the best!
Old 10-07-2009, 07:45 PM   #8
72chevy4x4
Guest
72chevy4x4's Avatar
Posts: n/a
has anyone used gutter stock for wide fascia? once in a blue moon I see an old building someone has bent regular sheet aluminum over a wide fascia and it looks awful. stock Alcoa is 0.019-some of the gutter/downspout material is .027 and 0.033-would the the thinner stuff be workable w/ a brake?
Old 10-07-2009, 08:32 PM   #9
Patrick
Guest
Patrick's Avatar
Posts: n/a
24g steel off the standing seam roofing coils or you can buy it in sheets, REALLY nice, and no bubbles you gotta pre-drill your nail holes though.
The gutter aluminum will can just like regular coil.
Old 10-07-2009, 09:43 PM   #10
Kgmz
Guest
Kgmz's Avatar
Posts: n/a
A thought for you guys regarding something to use to prevent oil canning in wider widths.
In commercial work we use a product that is 2 thin aluminum sheets sandwiching a ABS core. To bend you use a router V-bit and rout down through the back sheet of aluminum and almost through the ABS core, then you just bend it along the router line. Stays nice and stiff and smooth, and you can get it in a variety of colors, natural, or anodized.
Old 10-07-2009, 09:56 PM   #11
TimelessQuality
Guest
TimelessQuality's Avatar
Posts: n/a
got a name?
Old 10-07-2009, 10:28 PM   #12
Kgmz
Guest
Kgmz's Avatar
Posts: n/a
There are a lot of companies producing this some local, some national.
Alcoa Reynobond
Alcan Alucore, Alucobond, Dibond and more
and a lot of it coming from china
Just do a Google search for aluminum composite sheet or panel for your area.
The Following User Says Thank You to For This Useful Post:
Old 10-08-2009, 10:04 AM   #13
JoeT
Guest
JoeT's Avatar
Posts: n/a
Thanks everyone for your comments! I'll investigate some of these ideas.
Old 10-08-2009, 11:02 PM   #14
Tom Struble
Guest
Tom Struble's Avatar
Posts: n/a
gonna need a maxi break with the cutoff, the work tables help alot too
should only run you 3500 or so
Old 10-09-2009, 08:46 AM   #15
Jake Stevens
Guest
Posts: n/a
I used to use a panal board call Panel 15 which was a core board cover with steel or alumiunm on both sides. You could get it in 1/4",3/8" 1/2",3/4" and 1". It would be a smooth or pebble finish in many colors. We used it for commercial store fronts taking out 1/4" plate glass or insulated glass and putting the Panel 15 in it's place. It's been a long time sense I used it.
Old 10-09-2009, 11:47 AM   #16
Kgmz
Guest
Kgmz's Avatar
Posts: n/a
Panel 15 is still available, it was made by Weyerhauser for years and in the 90's that division was split off from Weyerhauser and is now called Citadel Architectural Products.
http://www.citadelap.com/panel15.htm
We started using it 30 years ago or so for built in place walk in coolers and freezers. They also have some other interesting type of panels.
Could hot aluminum fascia run power bill up? willworkforbeer Electrical 85 07-02-2009 11:10 PM
Aluminum Fascia eglanc Windows, Siding and Doors 38 05-02-2009 11:41 PM
aluminum soffit and fascia Something new General Discussion 11 05-01-2009 07:43 PM
wanted: Aluminum Fascia Roller jcalvin Tools & Equipment 38 02-05-2009 04:00 PM
How do you guys attach your aluminum fascia? dkillianjr Windows, Siding and Doors 30 11-14-2007 08:05 PM
