Fan Fold Insulation
Old 05-09-2007, 09:53 PM   #1
Home Serve's Avatar
Trade: siding windows soffit fascia
Question
Fan Fold Insulation
We have been into siding for a couple of years here in Central MO and have been looking for cost efficient ways to help folks reduce energy use. I personally like the sytrofoam backed siding (like polar bear) but it is pretty pricey for the extra R- value that you get. I believe a 3/8" foil backed fan fold gives the same or even more protection without all of the cracks.
What do you guys find that works well?
How about house wrap first? Good idea?
I have seen a product called "low e insulation" that is like a radient heat barrier. Think r value might be about 7. Ever use it and if so what result? at low-e.com
Thanks,
Home Serve is offline
Old 05-11-2007, 05:53 AM   #2
home improvement contract
mci2980's Avatar
Trade: home improvement contractor
Re: Fan Fold Insulation
I 3/8 mainly for the smooth / flat surface you can get if installed right. I find using 3/4 foam works great for soundproof quality and a little r value. It is difficult to do on houses with out sufficient overhang at rakes and eves.
What about blown in insulation? I dont deal with it but reccomend a guy when asked. People are usuallly surprised at the low cost. Home centers usually let you use the machine free w/ an average house size purchase of insulation.
good luck
mci2980 is offline
Old 05-11-2007, 12:00 PM   #3
Insert title
dougchips's Avatar
Trade: Doors-Windows-Decks
Prodigy is a R-5.
To get the best replacement windows, or sun rooms contact the replacement windows experts at FHI Vinyl Window Company.
dougchips is offline
Old 05-11-2007, 10:40 PM   #4
Home Serve's Avatar
Hey Doug, what is Prodigy?
We do have some insulation installers in our area that will fill the walls with cellulose or foam for about 1 thin dollar per sq ft. I think that is pretty good value for the customer!
Old 05-11-2007, 11:59 PM   #5
Insert title
dougchips's Avatar
Alside makes the product, it has a good r value and a nice warranty. It's has built in insulation and sits flat. I think the web-site is www.prodigy.com or you can find it via Alside's site.
Old 05-12-2007, 02:02 AM   #6
Super B
skyhook's Avatar
Fan Fold Insulation
I used something similar years ago for the outside of concrete basement walls set in Henrys 108. I like the R-15 for metal buildings.
skyhook is offline
Old 05-12-2007, 05:02 AM   #7
BABuilders's Avatar
Trade: Siding - Windows - Doors
we use alot of 3/8 foil backed green board. have even had customers use it and put polar wall siding over it!
A Touch Of Excellence in Every Home!
St joseph Siding Windows Doors and Decks
BABuilders is offline
Old 05-14-2007, 07:32 PM   #8
Home Serve's Avatar
Thanks BAB,
Good idea. What is the R of that green board? I'd expect that would in combo with the Polar would make a difference.
Old 06-28-2007, 06:28 PM   #9
JHD's Avatar
Trade: Vinyl Siding Installer
I am a big supporter of 3/8" fanfold. The R value is not terribly significant, but it does help. The major contribution, to me, is the rigid backing. Fanfold and wood lathe can work miracles on a curvy exterior.
I wouldn't bother with house wrap unless you're stripping the original siding off.
JHD is offline
THrown-in insulation: No soffit vents... Ted W Insulation 19 08-15-2009 12:35 PM
1950s Brick Ranch, No insulation but weird plaster type drwall. personalt Construction 5 01-21-2007 07:49 PM
2000 sf of ceiling...how to remove insulation? carlspackler Remodeling 8 11-26-2006 11:01 AM
Insulation question. Rich Turley Remodeling 14 06-11-2006 03:21 PM
Interesting attic insulation findings IHI General Discussion 5 02-28-2006 02:22 PM
