Fan Foam
Old 01-20-2007, 09:23 AM   #1
osborn's Avatar
Trade: Licensed Home Improvement Contractor
Fan Foam
Is fan foam always used? Its not used on new builds around here. Im doing a gut rehab. All new insulation and the vinyl will be over 1X subsiding.
osborn is offline
Old 01-20-2007, 03:41 PM   #2
house bldr's Avatar
Trade: general contractor
Re: Fan Foam
The biggest advantage to putting the fanfold on is to flatten the wall when going over old siding.On new construction or remodels where the old siding has been stripped it isn't necessary even though it does add a little r-value. I would definately go with a house wrap underneath if there is no old siding!
house bldr is offline
Foam Board vs. OSB JimmyZimmier Framing 17 11-06-2010 05:54 PM
spray foam? jcovey Construction 8 02-27-2010 09:19 PM
Sill Seal, i've always used the foam eXpatRioteX Framing 2 05-24-2007 06:28 PM
fastening wire + wrap to foam insulation mas Construction 0 07-07-2006 10:39 PM
Isulating with Foam for Roofs? FrankJr Construction 2 03-25-2006 10:05 PM
