Exterior Door On Windy Coast - Windows, Siding and Doors - Contractor Talk
Old 09-13-2018, 02:17 PM   #1
nesc39's Avatar
Trade: general
Rewards Points: 290
Customer needs me to replace an exterior door. The main building is on the coast and it gets very windy. The last door didn’t hold up because the wind grabs the door and rips the automatic door closer off. Senior citizens open the door and the thing practically rips off the building and slams into the wall. Previos door was cheap steel skin door with foam interior. Anyone have an idea other than solid wood that will hold up? It’s especiallY important that the area near the top of door is solid so I can mount a closure system that can handle a lot of force.
Building is a residential condo. It’s a side door going into wood framing with vinyl exterior. Basically same idea as everyday residential home
nesc39 is offline
Old 09-13-2018, 03:03 PM   #2
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 4,138
Re: Exterior Door On Windy Coast
Change the swing I assume its a out swing ?.
Still "Shakin" the tree boss
sunkist is offline
The Following User Says Thank You to sunkist For This Useful Post:
TheConstruct (09-13-2018)
Old 09-13-2018, 06:47 PM   #3
SPG's Avatar
Trade: Don't take trades, cash only.
Rewards Points: 486
What is everyone else using around there?
SPG is offline
Old 09-14-2018, 06:53 AM   #4
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 134
Get a commercial grade door - you can have the same issue with solid wood over time
Where is the closer - inside or outside? If inside you might consider going with exterior so the wind fights the closer as it is opening - maybe see what Hager & others have for situations like this
SLSTech is online now
Old 09-14-2018, 08:45 PM   #5
RickP's Avatar
Trade: Door Installer
Rewards Points: 392
Yes, a commercial hollow metal door with closer reinforcement. Install closer with sex bolts. Use a good quality closer with back check, not some Chinese crap. Your wood door frame is going to be your weak link, next.
RickP is offline
Old 09-14-2018, 09:00 PM   #6
RickP's Avatar
Rewards Points: 392
Fire code most likely won't allow it.
RickP is offline
The Following User Says Thank You to RickP For This Useful Post:
Lettusbee (09-14-2018)
Super Storm superseal Off Topic (Non Trade) 622 11-01-2013 01:02 AM
East Coast VS West Coast mpatel General Discussion 26 10-15-2012 06:44 AM
Windy days ECSOWNER Windows, Siding and Doors 12 03-06-2012 11:00 PM
east coast or west coast MScntrtr General Discussion 14 09-28-2011 08:11 PM
Coast to Coast ibonaol Business 1 06-22-2010 12:28 PM
