Can't Post
Trade: Construction
Exterior Casings With Integrated J Channel?
Can exterior casings be put around a window that has an integrated j channel?
Re: Exterior Casings With Integrated J Channel?
Yes make sure you have 6" or better window tape around the flanges, and I usually set the new casings into a heavy bead of caulk. sometimes I will even bend some U channel on the break to fit into the J pocket to A) prevent water from getting in there, and B) to give some surface area to put caulking on and set the new trim against.
Can't Post
Trade: Construction
Hi Patrick, Can you send me some pics that show what it looks like?
I do not have any pictures at my immediate disposal. It looks alright as long as the casing that is currently on the vinyl window is not a brickmould profile because then it will look kinda stupid and stand out as having double trim. What kind of siding are you using? Most window companies have an L fin adapter that covers the J pocket so you can use regular siding.
Sophisticated Siding Guy.
Trade: Siding and Trim Specialist
Whenever possible I try not to use caulk. Sometimes you have no choice but caulk eventually breaks down.
I was going to link you to some pictures but it says I need 15 post's before I can post URLs. |
Trade: Roofing Siding Windows
Duct tape it - yea caulk it - just do it
| Installing Hardi Plank Siding around windows w/ J channel | brownie77 | Windows, Siding and Doors | 8 | 11-21-2007 08:52 AM |
| Brick up against Slider with integrated J channel? | sandyman720 | Masonry | 3 | 09-22-2007 02:20 AM |
| Hat channel | tnt specialty | Drywall | 4 | 07-24-2007 08:32 PM |
| Vertical Cedar Channel Rustic.. | RISENRUN | Carpentry | 2 | 06-20-2007 12:46 PM |
| goodman integrated hsi module | Unregistered | HVAC | 20 | 10-25-2004 05:16 PM |
