Extension Jambs For Window
Old 12-21-2009, 12:39 PM   #1
davinci's Avatar
Trade: roofing
when installing new jambs,you guys use "smooth pine" ( 1 x's) ? or poplar smooth?
davinci is offline
Old 12-21-2009, 12:44 PM   #2
Project Manager
CookeCarpentry's Avatar
Trade: Project Manager
Rewards Points: 2,016
Re: Extension Jambs For Window
Depends on width, finish, budget, etc....
CookeCarpentry is offline
The Following User Says Thank You to CookeCarpentry For This Useful Post:
jeffatsquan (12-22-2009)
Old 12-21-2009, 12:47 PM   #3
Working
Cole82's Avatar
Rewards Points: 2,276
I like useing colonial door stop. It dresses it up real nice. 1x poplar is just for large gaps even then I like to dress it up and hit it with the router quick.
The boss of awesome
Cole82 is offline
Old 12-21-2009, 12:57 PM   #4
welterweight's Avatar
Trade: sales
we use a 1 x 5 in smooth pine. i think you are referring to a wide jamb.
welterweight is offline
Old 12-21-2009, 01:14 PM   #5
mrmike's Avatar
Trade: Electrical & Carpentry
I use 1x's premium pine, which I guess you are calling "smooth" . I try to get it with not many knots. I think your talking about extenting the jambs out to meet with flush to the interior wall..............
mrmike is offline
Old 12-21-2009, 01:16 PM   #6
Trade: sales
thats what we use. yes,i believe that is what he is referring too. i am guessing its also new construction.
a 1 x 8 in smooth pine costs us about 25 bucks.
Old 12-21-2009, 03:40 PM   #7
IHI's Avatar
Rewards Points: 1,040
All depends. Sometimes solid wood, sometimes wood veneer, sometimes MDF. Lately we've been using the heck out of "veneered door jamb" stock for stained applications since it's 1/4 of the price and still "looks" like solid stock. Really helps in the budget crunching putting projects together with no money per say....it gets them "the look" without spending big time bucks.
IHI is offline
The Following User Says Thank You to IHI For This Useful Post:
Tom Struble (12-21-2009)
Old 12-21-2009, 04:39 PM   #8
MJW's Avatar
Trade: General Contractor, Roofing, siding, windows
Rewards Points: 1,772
Whatever matches the trim. Usually it's solid oak. Pine with pine, and so on.
MJW is offline
Old 12-21-2009, 04:48 PM   #9
Motorboatin' son of a ...
BKFranks's Avatar
Mdf
BKFranks is offline
Old 12-21-2009, 05:55 PM   #10
wannabe
WNYcarpenter's Avatar
Trade: carpentry
Rewards Points: 1,000
For really wide extensions we'll use 1/2 AC... for regular extensions we use solid 1x. our local supplier carries select pine/poplar you could get either!?
stained,We match, ..........painted, as a standard is poplar.
WNYcarpenter is offline
Old 12-21-2009, 06:22 PM   #11
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
If it's less than 2 1/2" or so, I try to use rips from the base mldg... that way it matches nicely.
You might have to tighten up the casing reveal a little (thinner stock)
Otherwise, wrapped jamb stock or the real deal.
-Steve
TimelessQuality is offline
Old 12-22-2009, 01:55 AM   #12
cleveman's Avatar
Trade: custom home building
Rewards Points: 2,624
I started using tilebacker and tiling the jamb extensions.
cleveman is offline
Old 12-22-2009, 08:12 PM   #13
wannabe
Trade: carpentry
That sounds cool...any pics?.....I like that idea alot actually
Old 12-22-2009, 08:23 PM   #14
cleveman's Avatar
I haven't been successful posting photos. I decided to do this first in a basement, where the walls were firred out. The jambs must be 10 1/2" wide. I thought there was no way to use anything but plywood on something that wide, and they always get so dirty and beat up.
I brought out the tile the thickness of the window casing. In this case, it was the real cheap ranch style oak window casing, 2 1/4" wide. It is about 3/16" thick at the thin side, so I had the tile come out proud of the sheetrock by 3/16" and it is flush with the trim installed.
Just be sure to use porcelain (through and through), so the edges look nice. You'll find on normal windows (less than 4" extensions) you can use up your scraps.
Of course you could also use granite, marble, whatever. You could also use one-piece sills as is common in other parts of the world.
cleveman is offline
The Following 2 Users Say Thank You to cleveman For This Useful Post:
Tom Struble (12-22-2009), WNYcarpenter (12-22-2009)
Old 12-22-2009, 08:48 PM   #15
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 3,712
I just order them with the windows.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is online now
MAD Renovations (12-23-2009)
Old 12-22-2009, 08:59 PM   #16
NormW's Avatar
Trade: Builder
Rewards Points: 250
Poplar paints beautifully. That said, it's generally more expensive than clear pine, and it rots if exposed to moisture. I don't believe it stains well either.
I would use pine, unless I was doing stained work, than I'd match what was used on the actual window and/or trim.
NormW is offline
Old 12-22-2009, 10:35 PM   #17
CharlesD's Avatar
Trade: Remodeling/building
Rewards Points: 150
Like someone said theydid, I match the window. If I'm going in against a new vinyl window with wood extensions I like 5 Quarter Popular. I always use pocket holes to keep the joints tight.
CharlesD is offline
The Following User Says Thank You to CharlesD For This Useful Post:
Old 12-24-2009, 02:03 AM   #18
Scooter
Chasing Dreams's Avatar
Rewards Points: 250
Depends on what the customer wants. Pine, Poplar, Oak, Hickory, the flavors are endless.
One of the more popular flavors we have seen this year is using azek. Alot of customers that have had prevous experience with moisture damage along the sill want to use azek.
As long as the money is good, I would jamb it out in OSB if that is what the customer wanted.
I have a love/hate relationship with the white plastic myself.
The only two things I want to hear.....Wow, you're really expensive! I hope your not to busy.
Chasing Dreams is offline
hardwood floor and door jambs woodworkbykirk Finish Carpentry 33 12-05-2009 08:26 AM
Can I cantilever an extension to an existing deck? lot249 Carpentry 9 05-23-2009 12:27 PM
Extension Ladder and Landing Platforms newenergy Health & Safety 15 02-15-2009 05:14 PM
Cost of Repainting Door Jambs Faethwur Business 9 09-27-2008 08:59 AM
Window jambs extend beyond drywall jstrand23 Remodeling 21 04-26-2007 11:00 PM
