Door Sweep Puzzle...
Old 02-16-2009, 08:13 PM   #1
mdshunk's Avatar
I have to put a sweep on the bottom of my one door leading out of the foyer. Door opening presently has no threshold, and I will not install one. When I put a sweep on the bottom of the door, I can only open it part way because the floor is slightly higher as the door swings open, and the sweep gets tight on the floor. What are my options here, short of installing a threahold?
mdshunk is offline
Old 02-16-2009, 08:17 PM   #2
Patrick's Avatar
Re: Door Sweep Puzzle...
This should do the trick you can get them under a different brand at TrueValue too, just go where they have the door sweeps and look for the one thats the most expensive
http://www.amazon.com/36-Residential.../dp/B000KZV1X0
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline
Old 02-16-2009, 08:23 PM   #3
LRG WoodCrafting
Leo G's Avatar
As seen on TV Bwaaa ha ha ha hahaaaaa
http://www.asseenontv.com/prod-pages/tdrft_ontv.html
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 02-16-2009, 08:27 PM   #4
KemoSabe
loneframer's Avatar
Lean the top of the door frame out slightly, and pull the bottom in slightly, so that when the door opens it stays parallel to the floor. You can do it with hinge leaf placement too, but youll have to move the stops. This is hard to do if the jambs and stops are manufactured as one piece. If you lean the jamb out make sure the latch side stays parallel. It's an option.
loneframer is online now
Old 02-16-2009, 08:30 PM   #5
mdshunk's Avatar
oooooo... that's a neat idea. Wouldn't take much 'lean' over an 80" door to give a pretty dramatic rise in the opening sweep. I have a little bit of play between the slab and the stops, so I might just fill in the hinge screw holes, redrill them, and knife a little sliver out of the hinge mortise and see how that hashes out. Thanks.
mdshunk is offline
Old 02-16-2009, 08:30 PM   #6
LRG WoodCrafting
Leo G's Avatar
Use a nylon brush type sweep.
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 02-21-2009, 06:54 PM   #7
TRC
TRC's Avatar
Trade: Windows and Doors
Three things about leaning the door: 1. Your door could become hinge-bound. 2. You'll also have to putty the bottom mortise because it will have to moved out. 3. When the door is closed the slab will not be flush with the jamb up and down. I don't think Leaning the frame is a good idea either. If your talking about a very small distance then forget everything i said
TRC is offline
Old 02-21-2009, 10:51 PM   #8
KemoSabe
loneframer's Avatar
A true craftsman takes an imperfect world and and makes it LOOK perfect
Old 02-21-2009, 11:32 PM   #9
cleveman's Avatar
Trade: custom home building
You know there is some funky door sealer that drops down as the door closes and does the opposite as the door opens. It has been around for at least 20 years. They are used on pig buildings here to seal them up.
I don't know where to tell you to find them, however. I think the mechanism is actuated by the hinges somehow.
cleveman is offline
Old 02-22-2009, 12:15 AM   #10
Handle It!
MALCO.New.York's Avatar
Floating Sweep.
Seal-O-Matic.
Ultimate Wisdom---------
MALCO.New.York is offline
Old 02-22-2009, 08:17 AM   #11
jaros bros.'s Avatar
You're referring to a drop down seal. Check out www.pemko.com. They have a ton of options for just about every door application you can think of.
Josh Jaros www.jarosbros.com Remodeling in The Woodlands, Texas
jaros bros. is offline
Old 02-22-2009, 10:14 AM   #12
TRC
TRC's Avatar
What do you mean? Are you implying that some walls may not be plumb?? Naah, you must be kidding....almost had me though.
TRC is offline
Old 02-22-2009, 10:22 AM   #13
KemoSabe
loneframer's Avatar
That is why I like trimming the houses I frame myself, not to say I'm perfect because I'm not, but I dont get the surprises I would get following someone else, Like shoe plates that never get nailed down. Although that does make it easy to set the stops.
Old 02-22-2009, 10:27 AM   #14
TRC
TRC's Avatar
See I like that, your looking at the bright side. Mmmm...adjustable walls.
TRC is offline
Old 02-22-2009, 10:46 AM   #15
KemoSabe
loneframer's Avatar
I always like it when you have a load bearing wall with a large door opening in it and one side bears on plywood in the center of a bay, the other on the joist lap. I personally do punchout at the end of the day and add bearing blocks under all point loads.Most''PROS" don't even know what that means.
Old 02-22-2009, 10:49 AM   #16
LRG WoodCrafting
Leo G's Avatar
Is that like muffler bearings?
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 02-22-2009, 10:57 AM   #17
KemoSabe
loneframer's Avatar
Exactly. And my ad said carpenters, not car painters.
Old 02-22-2009, 10:59 AM   #18
LRG WoodCrafting
Leo G's Avatar
That reminds me of a joke.
This Carp enters a bar......
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 02-22-2009, 11:08 AM   #19
KemoSabe
loneframer's Avatar
and sets a little tiny piano on the bar along with a foot tall man. Bartender asks " where did you get that?" The guy pulls a lamp out and replies "rubbed this thing and a genie gave me one wish" Bartender grabs the lamp and rubs. Genie says " I will grant you one wish" Bartender says "I wish for a million bucks" Poof! There is a million ducks in the bar. First guy says "yeah, and I asked for a twelve inch pianist right?
GFCI and pond aerator puzzle JackJohnson Electrical 3 06-04-2008 08:13 PM
Mathematical Puzzle maj Off Topic (Non Trade) 11 10-06-2006 04:07 PM
