Door Replacement
Old 08-15-2005, 03:19 PM   #1
weekender's Avatar
Trade: handyman
Door Replacement
I was wondering if you guys can help me price a door replacement job.
Just the door not the frame. with new hardware and hinges.
weekender is offline
Old 08-15-2005, 03:34 PM   #2
Kevin's Avatar
Trade: misc
Re: Door Replacement
This should be an easy one man! What does the door slab cost? How far away? How much for hinges & locksets?
I'd probably charge about $100 on top of the materials.
Kevin is offline
Old 08-15-2005, 04:41 PM   #3
GMW's Avatar
Trade: Deck builder & Handyman
I usually charge $60-$80 depending on if there is only one or multiple doors. It only takes me about an hour if everything goes right
GMW is offline
Old 08-15-2005, 05:19 PM   #4
RJS's Avatar
Trade: Residential remodel
A $100 would work for me to hang it and install a standard lockset and deadbolt. Do you have to go pick the door up? Sometimes that can be a hassle, especially on a busy day and the door is coming from the orange box place. Remember your gas cost if the job is out of your area a bit. If its a full mortise lock...the price goes up considerably.
RJS is offline
Old 08-15-2005, 10:43 PM   #5
Teetorbilt's Avatar
I can easily spend over $100 on hinges alone. Picking the door up is another c-note. The hardware rarely lines up, figure at least another hour. Locksets can run from $12 - $600 + install. If it's an older home, many times the door may have to be shaped to fit, add another 1-2 hrs.
My average exterior door replacement runs about $500 for a frame home. You can pretty much double that for a CBS home.
Albert Einstein
Teetorbilt is online now
Old 08-16-2005, 08:43 AM   #6
weekender's Avatar
Trade: handyman
Thanks for your response guys. I have to replace 8 swing doors and 8 sliding doors.
Installing the recessed pull handles on hollow core doors can be tricking too.
any advise?
