Decoding An Andersen Window Sticker
Old 07-12-2008, 12:20 PM   #1
AustinDB's Avatar
Rewards Points: 470
I have an Anderson Flexiframe window (four to be exact) and would like to determine if they are Low-E windows.
AustinDB is offline
Old 07-13-2008, 12:03 AM   #2
grob62's Avatar
Trade: Windows and Doors
Rewards Points: 75
Re: Decoding An Andersen Window Sticker
I would look at the glass if I wanted to know if had Low E coating on it. The frame could be Andersen Flexiframe components and possibly some other glass. If it is an all Andersen product there should be an A/W Logo in one of the corners of the glass. Flexirames sometimes were just sold as extrusion lengths and setup shops would custom make whatever you wanted, and tell people, Yup, it's an Andersen, while only partially being true.
grob62 is offline
Old 07-13-2008, 02:18 PM   #3
AustinDB's Avatar
Rewards Points: 470
I found the triangular AW logo in the corner and I think it read 'clear glass' on the bottom of the logo. Seems they're not Low-E? There is a marking on the glass in a different location that it's tempered.
Andersen's site shows a label that is located on this window frame, but my label is incomplete-missing the information that lists the glass options.
AustinDB is offline
Old 07-13-2008, 05:20 PM   #4
Dustball's Avatar
How about calling Andersen customer service and give them the PO number listed on that label.
Dustball is offline
Old 07-13-2008, 08:54 PM   #5
Old Guy
jocobe's Avatar
Trade: Repair and Replace Windows and Doors
Rewards Points: 101
In the lower right corner is the AW logo. It'll either say Low-E or Dual Pane Clear.
You can call Andersen @ 1-888-888-7020 and give them the FX # from the label, which is 3818X1. That is the serial number that will tell them everything about that piece of glass.
jocobe is offline
Old 07-14-2008, 10:25 PM   #6
AustinDB's Avatar
Rewards Points: 470
great info-thanks for that. I'll call Andersen w/ the number.
AustinDB is offline
Old 07-16-2008, 09:15 PM   #7
Oberon's Avatar
Trade: Glass and windows
Rewards Points: 93
What you posted is an IG (glass) sticker and not a window sticker.
The information from the sticker is that there is no LowE coating on the glass.
Oberon is offline
Replacement Window Question? Max10 Windows, Siding and Doors 41 11-03-2013 12:01 PM
estimating guide for windows? Grumpy Windows, Siding and Doors 20 11-26-2010 08:18 PM
Condensation Help Patrick Windows, Siding and Doors 10 03-16-2007 09:40 AM
cutting window openings into brick faced house Mr. D Masonry 5 11-14-2006 01:55 PM
Andersen Window (1983ish) sash cord issue... old27 Windows, Siding and Doors 2 02-11-2006 12:06 AM
