Cutting Window Fins
Old 06-17-2008, 08:48 AM   #1
jvl's Avatar
Trade: general
Question
Cutting Window Fins
hi,what is the best ,easiest,cleaness way to cut vinyl window fins?thanks jvl
Last edited by Cole; 06-17-2008 at 02:40 PM. Reason: Moved to Windows, Siding and Doors!
jvl is offline
Old 06-17-2008, 09:29 AM   #2
Remodeling GC
kevjob's Avatar
Re: Cutting Window Fins
i score and snap with utility knife.
kevjob is online now
Old 06-17-2008, 10:02 AM   #3
I like Green things
WarnerConstInc.'s Avatar
I just buy the right ones.
WarnerConstInc. is online now
Old 06-17-2008, 12:50 PM   #4
Bob Kovacs's Avatar
Trade: Consultant
I guess the big question is, why would you want to? If you're talking about the fins that are integral to new-construction vinyl windows, they're there for a reason, and cutting them will both void the warranty and create a waterproofing/flashing issue.
Bob Kovacs is offline
Old 06-17-2008, 02:04 PM   #5
jvl's Avatar
Trade: general
what is the differance between a replacement window and a new construction window,the fins.the manufacturer says that you can cut the fins off if you like.this is a double hung window depth 31/2 and a single hung is 25/8.this might present a problem with appearance that the double hung might extend to far beyond siding.i like to figure everthing out before starting.the opening is plume and level and square along with watreproof membrane flashing along with z flashing.there are a number of different ways to cut this vinyl.i find it rather odd that some people respond without thinking.jvl
jvl is offline
Old 06-17-2008, 02:28 PM   #6
Bob Kovacs's Avatar
Trade: Consultant
hmmm...see, and there I was finding it rather odd that someone would post a question like "what is the best ,easiest,cleaness way to cut vinyl window fins" without giving any specifics that would allow a proper answer. I also find it odd that you want to butcher up a new construction window and use it for a purpose other than what it's intend for, especially when you already know it's not going to fit correctly (per your statements). Lastly "the fins" aren't the "only difference" between a new construction window and a replacement window- and any "manufacturer" that told you to cut the fins off and stick the window in the hole isn't someone I'd want to be installing windows from.
Old 06-17-2008, 02:40 PM   #7
Mod / ArchiBuilder
Cole's Avatar
Cole is offline
Old 06-17-2008, 04:36 PM   #8
Patrick's Avatar
The difference in width between a double hung and a single hung, would be noticed on the INSIDE not the outside. A Single hung with a narrow jamb would simply come with a jamb extension.
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline
Old 06-17-2008, 05:58 PM   #9
Bob Kovacs's Avatar
Trade: Consultant
Nah- he's going to pull the stops out, slide the window out from the inside until the inside is flush, and then caulk the crap out of what hangs out beyond the frame- it'll look like a custom job!
Old 06-17-2008, 10:11 PM   #10
Siding Windows Doors
easy sider's Avatar
Trade: Exteriors
On 90% of the windows and patio doors we install we use a utility knife to cut the fins. They charge $7.00 per window at the factory to cut them off the same way we do.
easy sider is offline
Old 06-17-2008, 10:45 PM   #11
Maxi-Pier Tech
essrmo's Avatar
Trade: foundation specialist
1 word, jambextension, don't you mean water table flashing.
essrmo is offline
Old 06-18-2008, 08:51 AM   #12
jvl's Avatar
Trade: general
the manufacturer is jeld wen located in el cajon calif.they manufacture the window in a mold that has a fin and if you want a replacement window then they will cut the fin off for you for $20.00.the siding of the house is cedar the extends off of the studs 1".i will extend the window out from the trimmer 3/4" so that the trim will be 1/4" beyond the window.the manufacturer also agrees that if the window protrudes out from the siding too far that water flow problems can occur.when i asked the simple question about cutting the fin i thought someone had a easier way to cut the fin like a plastic knife used on plexiglass,fein tool attachment,makita trim saw,bosch jamb/trimm cutter,recipecating saw or grinder with diamond blade attachment.dont want to use to much rpm,maybe a rotozip saw?
jvl is offline
Old 06-18-2008, 10:11 AM   #13
DavidC
DavidC's Avatar
To answer your question, a utility knife will do just fine.
But I would recommend against installing windows the way you desrcibed. There is a correct procedure to install a window with nail fins and a correct procedure to install an insert window. You described neither and could be headed for trouble.
Check your manufacturer's installation instructions.
Good Luck
www.CookContractingLLC.com
DavidC is offline
Old 06-18-2008, 11:50 AM   #14
jvl's Avatar
Trade: general
david c i have both the installation instruction for both new construction and replacement windows.the flashing methods are the same and the installation using stainless steel pan head srews 2" instead of 11/2" nails are the variation.i am installing a 2"false sill at a angle of 12% also z flashing at the top and bottom,i am using a waterproof membrane around the face of the exterior and liner on the inside of the 2x4 frame.all frame members are treated 2xs along with azek trim.interior will have a extension w/stool and apron.1/4 round trim where the dryway meets the jambs.careful attention is being made for the membrane to be wrapped properly ,overlapping correctly and caulking around window but not at bottom in order to let mositure drain.it is a cedar shake house with 30 lb paper with lap siding as sheathing.1940s house.please forward any additional information thanks jvl
jvl is offline
Old 06-18-2008, 03:06 PM   #15
easy sider's Avatar
Trade: Exteriors
JVL
I think you haven't worked with retro-fit replacement windows because if you have you would know that the fin is removed to install the window in the same location on the exterior as it is now. Jeldwen vinyl frames have three air chambers and two of these need to be in the wall for the frame to work as designed.
The Jeldwen window is the same width as the two wood windows that make up the old double hung. You would remove the stop on the inside and center to get the old windows out. The new window is placed into the opening from the inside of the house and the inside stop trim is re-used after caulking. Caulking is applied to the outside stop before window installation to seal the window and a piece of quarter round trim is installed at the sill if needed.
Old 06-18-2008, 03:46 PM   #16
jvl's Avatar
Trade: general
the old wood window is actually 31/2 in width plus trim of 3/4 attached to jamb that extends past the framing.the old window was all one piece sill,jambs,trim.theold window was termited out in the sill and jambs so the whole window plus framing wwas removed along with the rough sill and trimmers.granted before installing window it needs to be caulked and the extension jamb would serve as the interior stop and be caulked.exterior thecaulking around the window would be done, along with the trim coming up flush to the window and caulked again.i guess the trim would be your exterior stop?jvl
jvl is offline
Old 06-18-2008, 05:45 PM   #17
DavidC
DavidC's Avatar
There's the key. Your nail fin needs to be woven into that 30# felt to shed water. You may need to remove some siding to do it.
With the original frame removed you will need to use those nail fins.
Good Luck
DavidC is offline
Old 08-11-2008, 01:05 AM   #18
Vince01's Avatar
Trade: WINDOWS & DOORS
iF YOUR CUTTING BACK 'z fin' ON THIS TYPE OF WINDOW JUST TURN YOUR SKILLSAW BLADE BACKWARDS COMES OUT CLEAN IF YOU USE A STRAIGHT EDGE
Vince01 is offline
Old 08-14-2008, 12:44 AM   #19
grob62's Avatar
Trade: Windows and Doors
this is a double hung window depth 31/2 .jvl
All the ones I get are 3 1/4"
grob62 is offline
Old 08-14-2008, 09:44 PM   #20
cleveman's Avatar
Trade: custom home building
The alside windows I used last time had "snap-in" fins. They deliver all the fins separately and you have to cut them to fit and snap them in a channel, then drill holes for your nails or drive nails through. Probably not as waterproof a method as others, but it gets flashed anyway.
cleveman is offline
estimating guide for windows? Grumpy Windows, Siding and Doors 20 11-26-2010 08:18 PM
Replacement Window Question? Max10 Windows, Siding and Doors 34 02-27-2010 06:15 PM
cutting window fins jvl Windows, Siding and Doors 1 08-11-2008 01:07 AM
Cutting Window openings in block HemiMan2500HD Masonry 6 03-20-2007 10:33 PM
cutting window openings into brick faced house Mr. D Masonry 5 11-14-2006 01:55 PM
