Trade: carpentry
Cutting Holes In Aluminum Soffit For Can Lights
any hints for this. Our can lights measure approx. 6 5/8" . I usually just use a snips, but wondered if a hole saw would work? Or maybe a dremel with a cirlcle cutting attachment? thanks
#2 | |
Re: Cutting Holes In Aluminum Soffit For Can LightsQuote:
cheap drywall circle cutters ought to cut light gauge aluminum.
Trade: GC - Jobsite superintendent - General tool collector
Thats what I would do. You can also use a jigsaw.
-----oo00oo----- If i understood the source of my addiction I would get help, meanwhile I'll just buy another tool today. -----oo00oo-----
Handle It!
Re: Cutting Holes In Aluminum Soffit For Can LightsUse a jigsaw and leave tell-tale marks from the foot.
Trade: Home Remodeling
I make a template, run a sheetrock knike around is a couple of times then drill a hole next to the cut, take a pair of pliars and pull out the circle.
It works pretty much like when you open an aluminum can. |
Nahhh, not at all. I'll share an old trick with you but I think everyone else already knows this... foam tape on the foot, or even just a couple layers of masking tape. No marks at all.
Last edited by tool junkie; 08-24-2008 at 02:40 PM. Reason: cause I cant spell LOL |
...or blue tape on the work piece.
Handle It!
Blue masking works well.
Bah Humbug!
Personally I'd use a bi-metal hole saw.
Where did you get yours?
The largest I've seen was a 6" Morse, and that sucker was @ $130!
#12 | |
Bah Humbug!
http://cgi.ebay.com/ADJUSTABLE-HOLE-...QQcmdZViewItem If you can imagine it, it's probably already on Ebay. They should use that slogan and pay me royalties! Here are some more: http://www.toolsdirect.com/index.cfm...&source=ptyhpi http://www.service.kleintools.com/cg...D(A0150):31606 I'm not electrician, but would think if 6 5/8" were a common sized can light that there would be a vast array of hole saw availability in that size. And I was right, they seem to be marketed to electricians: http://www.electricsupplyonline.com/...-hole_saws.php |
#13 | |
The 6-5/8" hole saws are a stock item at my electrical supply houses, in both Greenlee and Lennox. The grit hole saw works better in aluminum soffet, since the teeth of the regular hole saw get really "grabby" with a cutter that big. You can run it in reverse for smoother action. I've used a RotoZip with equally good results.
#15 | |
the only guys that use one often enough to make it worth while for a dedicated size.
Re: Cutting Holes In Aluminum Soffit For Can Lights |
Trade: general contractor
roto zip with a circle cutter attachment works great, I use it all the time
#18 |
Re: Cutting Holes In Aluminum Soffit For Can Lights![]() |
#19 |
| Aluminum soffit estimate? | K_Tile | Windows, Siding and Doors | 24 | 07-25-2008 11:56 AM |
| Estimating Aluminum Soffit and Fascia | DaNortWoods | Roofing | 7 | 07-14-2008 10:41 AM |
| Cutting holes in plaster walls | Chris Simms | Electrical | 21 | 06-15-2008 09:16 PM |
| Cutting holes in plaster walls | Chris Simms | Drywall | 15 | 06-09-2008 07:58 AM |
| aluminum soffit | boo | General Discussion | 2 | 08-24-2006 10:08 PM |
