Cutting Hardi Radius On Wall
Have window replacements on some hardi with a new radius on top need to cut hardi on radius was thinking a routor with jig What type of bit or any other suggestions (grinder,ect.)
Re: Cutting Hardi Radius On Wall
I would use a cut off tool or grinder with those thin cut off blades.
Trade: Construction
Depending on the radius, I've had good success cutting curves with cement siding shears. A radius window should be a shallow enough curve that the shears would work fine.
Mac |
I think he is cutting this siding already mounted on the wall, so using the shears may be a little tough unless he can pull it away from the wall so the shears can move underneath.
Otherwise I like my shears for Hardie siding. |
I'm curious about the flashing detail
for the curved window under the existing siding. If we hadn't burned out on it, we could have gone through an entire sub-division replacing rotten sheathing and saturated insulation with new construction faux-palladians. I don't see a good way to flash these with out removing siding. I'm willing to learn though.
#7 | |
Trade: Construction
Re: Cutting Hardi Radius On WallQuote:
I'd want to pull the siding away from the wall no matter what I was cutting it with, to keep from cutting into the flashing/tar paper beneath. Just jam a couple of shim blocks under the siding to push it away from the wall and cut away. Flat bar and cat's paw to remove nails if he has to completely cut through (top to bottom) a full piece of siding. Side note, shears are SO nice for cutting Hardi w/o kicking up a ton of concrete dust! Mac |
Sophisticated Siding Guy.
Trade: Siding and Trim Specialist
I hate the shears. They cut rough as hell especially while cutting a radius.
The pieces of plank need to be taken off and put back properly. Since I would have them on the ground I would just use my jigsaw that cut's smooth as butter. Imo it would be faster to take of the pieces and redo everything properly than trying to quick fix this one. Like someone stated this is such important flashing detail that get's over looked that it's not a good spot to cut corner's. |
Bah Humbug!
My guys can cut straight lines as smooth as a circular saw.
My guy's can to but there slow. The snips work for the first 50-100 sq. Then you have to flip the blades or by new ones because there dull.
Nothing beats a 12" chop saw with a vacuum hooked up to it. When I need 5 pieces the same length they measure one and cut 5 at once. Smooth as a factory cut. I'm getting ready to do 3 hotels that are each 300 plus squares of plank. There's no way I could do a job that size with my guy's using snips. If your hanging a couple square a day sure the snips are fine. |
Builder/Remodeler
Carbide grit jig saw blades work very well for cutting hardiplank and leave a pretty decent edge.
I get them at Lowes.
![]() Christopher Wright, CR: President @ WrightWorks, LLC/President @ Central Indiana NARI, Named to the 2010 REMODELING Big50 www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here |
| Help with a two story radius wall. | BirmanBuilders | Framing | 23 | 02-12-2012 06:27 PM |
| Wall to ceiling radius | JohnV | Drywall | 12 | 01-30-2008 09:04 PM |
| tips for cutting into a ceiling / wall corner | Zeebo | Painting & Finish Work | 30 | 11-30-2006 09:36 PM |
| Cutting Hardi Back | troyamuso | Kitchens & Baths | 22 | 11-17-2006 09:27 AM |
| Determining Manhours for rolling vs. cutting - your suggestions would be helpful | Zeebo | Painting & Finish Work | 9 | 06-02-2006 06:12 PM |
