Trade: roofing
Cutting AZEK Trim Boards
someone told me bending azek with a heat blanket can cause problems..anyone have an idea what those problems would be?
i was told the best way is by using a jig saw..i would imagine you would have to sand the edges..do you hand sand or use an electronic sander? |
Trade: siding
Re: Cutting AZEK Trim Boards
for a circle or arch top id try to set up a trammel and a router
i don't no how to set it for an elipse but im sure theres a way but i have done it with a jig saw too if its a new window and i had the time i would probably just order a fypon head
Tom |
Smart phone? Scan me!
Trade: Painting/Framing/Drywall
Re: Cutting AZEK Trim Boards |
| The Following User Says Thank You to nEighter For This Useful Post: | BKFranks (11-18-2009) |
Awesome video, nEighter! Any idea how much that system is?
Nick Schiffer Specializing in Custom Sheds Custom Carpentry & General Construction |
sorry please delete... double post
Trade: Exterior Construction
That Azec can be bent quite easily as shown. We have seen it bent into some funky shapes before.
Good vid. |
| The Following User Says Thank You to BlackHatch For This Useful Post: | nEighter (11-19-2009) |
#7 | |
KemoSabe
Re: Cutting AZEK Trim BoardsQuote:
Now you need two guides set at 90 degrees of each other to glide the pins of the trammel along, they will need to extend at least as long as the two dimensions together. As you guide the pins along the jig, starting from a vertical position and ending in horizontal the router will follow an elliptical path.
__________________________________ "Walking the fine line between production and perfection" __________________________________ |
| The Following User Says Thank You to loneframer For This Useful Post: | Tom Struble (11-19-2009) |
Trade: siding
i saw a jig in fhb using bi fold door wheels running in slots
easier to order fypon
Tom |
I have always used a router to cut elliptical shapes. Cutting an elliptical shape with a jig saw would just cause alot of unnecessary work. There is a video on Gary Katz's website about cutting elliptical shapes with a trammel arm. If you are cutting plain circles try the Arcus blade for a skil saw.
Trade: Roofing, Siding, Windows, Remodeling
I have used heat pads on quiet few occasions. They work really well except you need to get some experience with it. The problem is with setting up correct temperature for width and thickness. If you under heat - they won't mold easily and will buckle. If you over heated it you are running a risk of burning them. Another problem is to make a flat jig for them. Not a biggie but extremely important.
To eliminate any imperfections I run molded pieces through wood planer. Unfortunately the are not cheap. 12' section runs for $1700-1900 and 20' around $3000 They are well worth it if you have enough job. I had one big contract that well paid for using those heat pads. Molded trim cost above $150.00 per piece. Imagine doing it yourself for $15.00. Hope it helps |
| repairing trim coil wrapped garage | Home Serve | Windows, Siding and Doors | 17 | 08-18-2009 08:10 AM |
| vinyl siding cutting table | platinumLLC | Windows, Siding and Doors | 16 | 08-15-2009 11:54 AM |
| Brick / Paver Cutting Question | Tool Researcher | Masonry | 24 | 04-15-2009 12:25 PM |
| Pricing new homes for trim? | woodworkbykirk | Finish Carpentry | 24 | 01-26-2009 10:26 PM |
| Composite trim and adhesive questions | JLTrim | Finish Carpentry | 4 | 10-12-2008 04:55 PM |
