Corrugated Metal Siding Window Sealing
Old 09-19-2012, 06:50 PM   #1
Love What You Do !
livingsoulsdie's Avatar
Rewards Points: 150
I cant find any definitive info in manufacturer specs with these specific windows. I have 2 pole barns to side with vertical corrugated metal and have to install roughly 10 windows. The windows have flanges and I must cut the J-channel. My question is this. Has anyone done this installation before? If so, what is the best way to water seal around the window? I know how to install windows & trim with vinyl siding , unfortunately this method will not work and will surely leak with the vertical corrugated metal. Im thinking of mabey bending a drip cap that protrudes 1/2 in past each side of the window and just kerfing the siding to accept it? Is this the proper way? If not let me know. Here is a pic I found on google of the siding type im using. Any input would be appreciated. Thanks guys.
livingsoulsdie is offline
The Following User Says Thank You to livingsoulsdie For This Useful Post:
Tom Struble (09-20-2012)
Old 09-19-2012, 07:27 PM   #2
TimNJ's Avatar
Rewards Points: 2,694
Re: Corrugated Metal Siding Window Sealing
I don't get why you have a problem.
How are you handling siding against a man door. Should be basically same detail shouldn't it?
TimNJ is online now
Old 09-19-2012, 07:33 PM   #3
slowsol's Avatar
Rewards Points: 2,212
I can't understand why you can't J around the windows?
-John
slowsol is offline
Old 09-19-2012, 09:49 PM   #4
Love What You Do !
Rewards Points: 150
Because the water that will run down the J will run right behind the siding and into the building.
Old 09-19-2012, 10:01 PM   #5
donerightwyo's Avatar
Trade: custom builder
Rewards Points: 650
That's how it's done. Top first, then sides, then bottom. They don't leak like you think they would.
I can't compete with hacks.
donerightwyo is offline
The Following User Says Thank You to donerightwyo For This Useful Post:
Gary H (09-20-2012)
Old 09-19-2012, 10:40 PM   #6
VinylHanger's Avatar
Rewards Points: 7,580
That's the same way vinyl works.
VinylHanger is offline
Old 09-19-2012, 10:56 PM   #7
Designer/Contractor
Rio's Avatar
Rewards Points: 1,818
Ask the metal siding providing if they have any details.
Rio is online now
Old 09-19-2012, 11:19 PM   #8
The Dude
smalpierre's Avatar
Trade: home improvement
Rewards Points: 1,946
I think you got that one backwards. bottom first, then sides, then top. Same as flashing a chimney or most any other water shedding system.
OP: you're probably not going to be making that J with a 4' brake unless the windows are tiny. You probably will have to make your own or farm it out to a metal guy.
"That somebitch looks like MANAGEMENT MATERIAL TO ME...I would have handed him another rod after he bent the first one." ~MAULEMALL
"I think he was grandmaster at a gay pride parade in san fran this week (not that there's anything wrong with that). " ~ J F
smalpierre is offline
Old 09-20-2012, 05:09 AM   #9
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
windows should be water tight before any siding or trim gets on the building,don't use j at the window head,cap over the head and side j with a Z drip cap then j above that to close off the bottom of the panel
Tom Struble is offline
Old 09-20-2012, 05:12 AM   #10
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
I wish more people understood that. I am so tired of people and their the siding is water proof ir their the tile makes it waterproof, and my favorite; shingles never leak, you dont need tar paper.
ohiohomedoctor is offline
Old 09-20-2012, 05:21 AM   #11
Trade: siding
Rewards Points: 20
well to be fair there's probably no sheathing or conventional drainage plane behind the metal?
The Following 2 Users Say Thank You to Tom Struble For This Useful Post:
donerightwyo (09-20-2012), livingsoulsdie (09-20-2012)
Old 09-20-2012, 05:36 AM   #12
Love What You Do !
Rewards Points: 150
Exactly. There are just wall girts holding the window.
Old 09-20-2012, 05:37 AM   #13
Love What You Do !
Rewards Points: 150
Im not going to even comment on this one.
Old 09-20-2012, 05:41 AM   #14
Love What You Do !
Rewards Points: 150
Ohh btw. They do leak if you do it the conventional way. I have seen experienced siders make this mistake with corrugated metal & I dont want to make there mistake. Please leave the BS comments on someone elses post.
Old 09-20-2012, 07:09 PM   #15
Trade: siding
Rewards Points: 20
maybe use sheet stock under and around the unit to create a drainage plane?i think metal would be more durable if the inside is not going to be finished,you could put a bend at the sides to keep water from blowing past sideways?...follow my drift?
Old 09-20-2012, 07:11 PM   #16
Trade: siding
Rewards Points: 20
you can buy it
Old 09-20-2012, 07:29 PM   #17
Trade: siding
Rewards Points: 20
duh..i just reread your post and realized your just replacing the windows
either way i don't see how you can without dismantling the siding and j trims from around the existing unit
Old 09-20-2012, 07:59 PM   #18
Love What You Do !
Rewards Points: 150
It still seems like the drip cap is winning out to prevent the majority of water flow to the sides J's. After looking at the specs on the document you sent me it is just looking as if the cap is the only defense against the water running down the channel and behind the siding. As for a drainage plain since the wall girts or purlins (if thats what you want to call them) are 2' OC's I think I will run ice & water shield from the top of the window all the way to the bottom of the siding. Install the window with flange on top of the Ice & water & silicone the backs of the siding when installing. Think it will work?
Old 09-20-2012, 09:43 PM   #19
Rewards Points: 650
Well yeah, but we put the top up first, then the sides, then the bottom, so as to be able to butt into the previous piece. Then the tabs are bent over.
Old 09-20-2012, 10:03 PM   #20
Rewards Points: 650
So I don't know much about this kinda stuff. The architect on our last job spent two hours photographing and sketching our work so as the drafters would know how it should be done.
We don't get huge amounts of rain, but have never had any problems doing it as stated. I've never seen it done any other way. Steel and vinyl siding are done this way to.
Only thing to keep in mind for however you do it is being able to get the pieces in. First one is easy, getting the second one in the J and lapped not so much.
Made in USA product list J.C. General Discussion 360 06-16-2018 04:52 PM
Barn Siding - Batten Nailing Technique artinall Windows, Siding and Doors 9 07-13-2012 05:03 AM
Shed picture. lmahome Carpentry Picture Post 14 05-25-2012 11:19 PM
Northern Virginia-Roofing, Siding, Window Installers Skydawggy Help Wanted or Looking For Work 0 08-26-2010 07:00 AM
corrugated metal duburban Roofing 7 12-28-2008 01:09 PM
