Corner Board Over The Siding Or Against The Building?
Which way do you prefer it? Most houses around here are done with the corner board nailed right over the siding. But most the siding jobs I've done had the corner board nailed to the sheathing with siding butted up to it.
#2 | |
Re: Corner Board Over The Siding Or Against The Building?Quote:
As a homeowner: siding butted to the corner
Re: Corner Board Over The Siding Or Against The Building? |
DavidC
Easy job = over the siding. Cut lengths to within 3 1/4", close enough. Slap corner corner board over ends. Open beer, return to HO weekend.
I've never seen that on any house. Are the window/door casings done the same way? Good Luck Dave
www.CookContractingLLC.com |
wannabe
Trade: carpentry
What type of siding?
I've seen wood corners nailed over Novelty siding, or board and Batten not beveled siding. Vinyl makes it look like the corner has been applied on the siding, but vinyl is vinyl....I'm not a big fan. The voids, IMO, invite bats, hornets and other creatures. I can't think of any scenarios where I would be comfortable applying the corner over the siding.
"I knew I lost my wallet as soon as I threw my pants over the fence". -'lil jarhead bro when asking for a wire transfer... |
The Deck Guy
I guess they put the cornerboards over the siding in the ghetto....
That's just cheesy-yikes!
#7 | |
wannabe
Trade: carpentry
The only wood siding I know of in the ghetto is rotting behind vinyl
Professional way:Butt
https://www.facebook.com/pages/John-...94183374011504 |
General Contractor
Trade: General Building Contractor
Like this:
#10 | |
The job I'm working on is a lawsuit job where the builder didn't put on any house wrap under the siding. So we are tearing off the old siding, re-sheeting and re-siding it. The window trim was done the same way, with the trim over the siding. ![]() We are using Hardiplank siding and we're only redoing 3/4 of the house, we are leaving the front the way it is. For some reason they decided to put on house wrap in the front but not the rest of the house. So we are going to leave the corner board that they did the way it is, with it nailed over the siding. But we'll do the rest of the house with all the window trim and corner board nailed to the sheathing first. We're doing it that way because the way the windows are arranged, we will save about 200 little pieces of siding by nailing the trim right to the building. Basically we were worried about the gaps it leaves when you run the corner board over the lap siding. When we tore everything off, we found they didn't put any caulking or anything behind the corner boards. So there is nothing but air between each gap and the building. I don't see what's to stop water from getting in those gaps and into the building. If you were using plywood, T1-11 siding, then I can see doing it that way because you wouldn't have any gaps. But with any kind of lap siding you have a half inch gap on every course. We asked the inspector which way he prefers it. He said personally he likes to have the corner board nailed to the building with the siding butted up to it. But he said he can't enforce that because it's legal to have trim on the outside of your siding. I have never heard of water damage caused by nailing corner board to the outside of siding, so maybe it's o.k, I don't know. But I still wonder why most builders do it that way. Some people claim it saves time, but it seems to me I can put on siding just as fast by butting it to the trim as I can by nailing the trim over the siding. And in some cases you can save time nailing trim right to the building, such as when you have two windows close together, then you can omit the siding between it. |
Trade: siding
i like my trim to have a pocket or to be packed out the siding ran to the packout then the trim installed over the top
i dont like all that caulk that you need to do when you butt the trim that being said just nailing the trim over the siding is a cheesy detail
Tom |
Smart phone? Scan me!
Trade: Painting/Framing/Drywall
here trim goes up, and siding butted to it (lap) and for vertical it is over the siding and caulked.. As far as caulking goes.. a good sider can get it within 1/8"-3/16" (on lap) and caulking isn't much of an issue, and doesn't make it look bad at all. It is the HACKS that put the lap siding out 1/2" or more.. then it is all up to the painters to make up for ****ty craftsmanship.
EDIT: I meant for vertical it is over the siding and caulked.. not horizontal.
Olathe house Painting and Remodeling Overland Park Interior House Painting Leawood Exterior House Painting Shawnee Wood Rot Repair Lenexa Drywall Repair Last edited by nEighter; 09-09-2009 at 01:31 AM. |
wannabe
Trade: carpentry
Atleast put your house wrap on right side up...it's a point of pride...
Someone didn't take enough pride to to even put on tyvek neatly...granted it doesn't make any difference...but that's called attention to detail.
#14 | |
wannabe
Trade: carpentry
If you can't get within 3/16, you suck or you just don't care! find a different career.... I'm not talking to you nEighter...just speaking in general....
| The Following User Says Thank You to WNYcarpenter For This Useful Post: | nEighter (09-09-2009) |
Trade: General Contractor, Woodworker
There are people everywhere who install corner boards (and even window & door trim) over the siding. I don't believe it is ever correct- it's mostly done for ease and speed, never for quality.
how about lap that is "lapped" right up against the window.. so it goes lap siding then window.. no trim at all!
I think this is one of those things that's best not to have an opinion on. As soon as you assume and do it one way, someone else can come along and say "no, that's wrong" which ever way you do it.
#18 |
Trade: contractor
Depends on the $$$$$... all the rest of the rhetoric is BS.
#19 | |
Trade: siding
hey pal unless your a lefty you dont know what its like trying to put tyvek on the ''right way''
Tom |
| The Following User Says Thank You to Tom Struble For This Useful Post: | Framer53 (09-09-2009) |
| ABC Supply Co. Inc. Acquires Chesapeake Siding and Roofing | Grumpy | Roofing | 0 | 03-03-2009 09:40 AM |
| Commercial Building Renovation Questions | cacwgrlc | General Discussion | 13 | 11-22-2008 04:37 PM |
| Help with - Inside corner trim for vertical cedar siding | wallmaxx | Framing | 3 | 07-22-2007 06:47 PM |
| Ledger board flashing, inside corner | mickeyco | Decks & Fencing | 3 | 12-12-2006 10:59 PM |
