Condensation On Windows
Old 02-12-2007, 08:59 PM   #21
Oberon's Avatar
Trade: Glass and windows
Re: Condensation On Windows
thatguy,
Not necessarily. If it gets cold enough outside then the inner pane of glass can definitely get below freezing allowing ice to form on the edge of the glass or on the edge of the frame.
Obviously a leak that would allow cold air into the home could make this situation worse, and checking for leaks is a very good idea, but even a tight window without leaks can still freeze given the right set of circumstances.
As LennyV noted, it is generally worse when aluminum is involved.
Oberon is offline
Scouring Pad for Cleaing Windows WNYcarpenter General Discussion 23 08-05-2009 01:22 PM
quaker windows truckman Windows, Siding and Doors 9 04-30-2007 07:46 PM
Windows & doors from AWS T bone General Discussion 6 04-06-2007 04:35 PM
Condensation Help Patrick Windows, Siding and Doors 10 03-16-2007 09:40 AM
Condensation inside windows rjordan392 Windows, Siding and Doors 12 03-21-2005 12:17 AM
