Condensation ?
Old 01-04-2009, 06:13 PM   #1
Fentoozler
Celtic's Avatar
Condensation ?
If water is beading between panes of a typical DH window, is the only possible culprit condensation?
We had some windows installed awhile back and of the dozen or windows, one window's upper section now has water droplets on it.
Any other possibilities?
Celtic is offline
Old 01-04-2009, 06:52 PM   #2
Thom
thom's Avatar
Re: Condensation ?
I'll do you one better, I have a 25 year old patio door with 6" of water between the panes. Many windows have what looks like efflorescence between the panes.
thom is offline
Old 01-04-2009, 06:53 PM   #3
Re: Condensation ?
Moisture between the panes of
double pane/insulated glass?
Warranty issue.....
Call your glazier!
neolitic is offline
Old 01-04-2009, 06:59 PM   #4
Thom
thom's Avatar
Re: Condensation ?
it's only a warranty issue in the first year.
thom is offline
Old 01-04-2009, 07:03 PM   #5
Fentoozler
Celtic's Avatar
Re: Condensation ?
I'm *hoping* it's under warranty ~ I just need to find my paperwork from the install
...w/o that, I just may have 6" of water in there in a few years
I don't remember if the windows were installed during '07, '08 ....have to find the contract.
I am actually more concerned with the water/condensation issue than locating the paperwork.
Celtic is offline
Old 01-04-2009, 07:28 PM   #6
Burby's Avatar
Trade: Remodel / repairs / Certified Mold inspector, Remediator
Send a message via AIM to Burby
Re: Condensation ?
Most previous glass 10 year warranty & 20 year warrenty for newer glass.
Look on the spacer bar, copy the numbers & letters down, call the manufacturer & they will tell you if under warrenty or not, then if so they will send a rep to inspect.
Proud to help make a house your Home
Never judge another by one's own intelligence
Burby is offline
Old 01-04-2009, 07:33 PM   #7
Fentoozler
Celtic's Avatar
Re: Condensation ?
It's definitley under warranty...I just want my paper trail complete to minimize any BS slung my way
Celtic is offline
Old 01-04-2009, 07:36 PM   #8
enforcer's Avatar
Trade: windows-siding
Re: Condensation ?
seal leakage,common in cheap windows. the gas leaks because of seal failure and presto,condensation!
customers get what they pay for.
enforcer is offline
Old 01-04-2009, 07:50 PM   #9
Burby's Avatar
Re: Condensation ?
Yeah that makes sense, but for me, finding paper work for my stuff??? hahaha, I would call the manufac first then depending on what they said begin ah digging..
But seriously, I guess there are some out there that would find something to void your warrenty, but for the most part, my experience, I have not run into it. A new sash is far cheaper than having a customer bad mouth the Companies name.
I have seen more times than not a door or window company will pay me to do a repair even if not the fault of the product just for that reason.
I would contact the Manufac & ask for the service department, explain, give them the numbers & go from there. Those numbers & letters tell them all they need to know to schedule an inspection. Depending on brand, they may just send you a new sash to save the cost of the rep visit.
Then if you feel you need your papers, then dig like hell..
Good luck
Burby is offline
Old 01-04-2009, 08:43 PM   #10
davewindowguy's Avatar
Trade: windows and doors
Re: Condensation ?
if condensation is between the two panes of an INSULATED piece of glass it means your seal of your insulated glass has failed. you need new glass. If it has happened on alot of your windows you should contact the manufacturer or your window dealer for warranty info. and most likely you bought a low grade window. higher grade windows will warranty seal failure for 20yrs or lifetime. if you choose to replace the glass from another company, look for Cardinal IG.
davewindowguy is offline
Old 01-07-2009, 07:57 AM   #11
Instructor, ex-contractor
critter's Avatar
Trade: Construction trades Instructor
Re: Condensation ?
Correct call on the seal failure, inert gas is gone and vapored air has gotten in. The patio door can be removed and carefully drilled up through the dessicant strip to drain the water for now. If the door is wood, water will destroy the bottom rail in time,though. Around here, we can get a reasonably-priced new inulated glass-only panel, if the door stiles and rails design allows for replacement. -United Plate Glass- Just a thought...
critter is offline
Old 01-07-2009, 05:01 PM   #12
Fentoozler
Celtic's Avatar
Re: Condensation ?
Originally Posted by critter View Post
Correct call on the seal failure, inert gas is gone and vapored air has gotten in. The patio door can be removed and carefully drilled up through the dessicant strip to drain the water for now. If the door door is wood, water will destroy the bottom rail in time,though. Around here, we can get a reasonably-priced new inulated glass-only panel, if the stiles and rails design allows for replacement. -United Plate Glass- Just a thought...
Dude...it's a window
Celtic is offline
Old 01-07-2009, 05:12 PM   #13
Bah Humbug!
Grumpy's Avatar
Re: Condensation ?
Are the droplets ON it or IN it? If in it; It's not condensation so much as it is a seal failure. You can get new glass units if you don't want to repalce the entire window.
If on it; Turn down your humidifier.
Grumpy is offline
Old 01-07-2009, 05:26 PM   #14
Fentoozler
Celtic's Avatar
Re: Condensation ?
They are IN it....I tilted the upper to feel both interior/exterior glass....the droplets are ON the glass inside.
These windows are MI "XACT" 2650's [if I recall]
Celtic is offline
Old 01-08-2009, 09:53 PM   #15
critter's Avatar
Re: Condensation ?
Hey Celtic, DUDE, I was talking about Thom's patio door. Remember? I said DOOR. ...And to answer YOUR question - NO, no other possibilities - the seal FAILED. Spend more energy thinking about what you read - and less being a wise guy, okay?
critter is offline
Old 01-08-2009, 11:31 PM   #16
Re: Condensation ?
Doode, spend more time thinking about
what you write (maybe even try the quote
button).
It's hard to guess what you are thinking
or who you're talking to.
neolitic is offline
Old 01-09-2009, 02:11 AM   #17
Tom Struble's Avatar
Trade: siding
Re: Condensation ?
oh thats what that quote thingy does hummm
Tom Struble is offline
Old 01-10-2009, 10:49 AM   #18
Fentoozler
Celtic's Avatar
Re: Condensation ?
No, it's not "okay" DUDE.
Learn how to use the forum and the tools provided on it before telling someone else how to act.
Celtic is offline
Old 01-10-2009, 11:58 AM   #19
advanced_energy's Avatar
Re: Condensation ?
I am going to show this post to the next person who claims my window pricing is too expensive. you GET WHAT YOU PAY FOR !
this is a classic case of seal failure.
advanced_energy is offline
Old 01-10-2009, 01:04 PM   #20
critter's Avatar
Re: Condensation ?
button).
Sorry Neo and Celtic. I'm an older guy and I guess all Celtic's bold type made me a little grumpy - or was it the crappy day I had? I forget. Anyway, you're both right that I can't get any of my forum tools to work - except the quote feature. Even parantheses come out as revealed formatting. I think my java console is all jacked up so anything that needs it doesn't work. Tried java download fixes and realoads - no luck. Again, I didn't mean to offend you guys.
critter is offline
metal building condensation 21sapptk General Discussion 6 12-25-2008 08:31 PM
condensation issue altonarch Introductions 3 11-23-2008 10:51 PM
Condensation Lawsuit? Travis Roofing 34 11-07-2008 04:41 PM
Condensation Help Patrick Windows, Siding and Doors 10 03-16-2007 09:40 AM
Fuel Tank Condensation denick Excavation & Site Work 3 05-26-2006 09:29 PM
